PA Cresta running 'problems'
Results 1 to 7 of 7
    Aug 2009
    South Cheshire
    1,408
    50
    RockabillyBilly is online now
    Hello all. Just wondering if any PA Cresta (or similar) owners have had this problem. When I put my foot on the accelerator to set off; the car hesitates for a second before moving (almost 'coughs' for want of a better expression). Also, when i'm going along and I put my foot down, it does the same. It's hard to explain in writing but it sort of almost cut's out for a split second before doing what it should. I think it may be fuel related because, while the automatic choke is on, all is fine, it's when it's off it starts this problem. Also, on the 'over run' it kind of burbles/judders etc and, from memory of my last 6 cylinder engined car (20+ years ago) it shouldn't, I don't think. Any ideas would be gratefully accepted.
    2.6 Straight 6 engine. Manual.
    23,476
    Usual suspect there is the accelerator pump/ jet. Filter off, engine off, peer down carb and pull on accelerator and you should see a jet of fuel squirt into carb, no jet and there's your problem.
    Burble / judder , standard exhaust system ? Change of silencers can make this happen .
    Aug 2009
    South Cheshire
    1,408
    50
    Thanks Kapri. I checked that; good steady spurt there. Standard exhaust. When I put 'burble' that almost makes it sound like a good thing. Haha. Another description would be; it almost feels (on the over run) likes it's '2 stroking'. Another description but, reading it back..not necessarily a better one. Thanks for the input so far. Much appreciated.
    Rods 'n' Sods Junkie Low Expectations's Avatar
    Bucks
    350
    83
    Low Expectations is offline
    Hi Billy. Got yourself another Cresta then? Put some pics up.
    As for your problems, i'd start with the basics. Check timing & points (put a new set in along with condenser plugs & leads, air filter). Also i'd see if its pulling in air (spray some easy start around the carb & inlet manifold while its running & see if the revs rise). Then take the carb off & give it good clean. If its still got the problem then it is probably ****ed.
    Jul 2011
    sidmouth devon
    2,547
    385
    dave 62 pb is offline
    Hi Billy, Check inlet manifold for air leaks as some had metal gaskets,use blue hylomar, also check that the hot spot plate in the exhaust manifold is not stuck in the open position allowing heat to rise as this will evaporate fuel when engine hot (I weld them in the shut position to the shaft which is always siezed solid then pack the void/chamber betwwen the manifolds with fibre glass insulation mixed with exhaust paste.
    Some models also hade a breather valve on the inlet manifold (pipe from valve cover goes to it ) make sure its not stuck open or better still removeit and blank it off.
    They are a great engine and so smooth /quiet when running properly
    If there is anything you need to know or I can help with you can pm me
    Cheers
    Dave
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    do you mean it keeps running (although roughly) after you've switched it off?
    Aug 2009
    South Cheshire
    1,408
    50
    Thanks all; Danny. Yep, got another one but not quite in the mood to post pictures just yet. Haha. I'll do what you suggest. Regarding your last statement; it's me (at the moment) that's f****d!
    dave 62 pb: Good point, I'll check it/them out if I'm fit enough, later. Thanks also for your offer. I may be taking you up on that.
    streetfighter; No, it doesn't do that. (You mean like a kind of 'pre-igniting' thing I think) No, apart from the 'hesitating' and rough running issue, all is fine. Well, it isn't but you know what I mean.
    Cozmic; Thanks for the advice on the 'phone.
    Thanks again all for the input so far.
    1. Rambler running problems
      By klassicdave in forum Tech Discussion
      Last Post: 05-05-2014, 22:13
    2. pc cresta running bad
      By jollyjibblet67 in forum Chat
      Last Post: 20-03-2012, 17:30
    3. running problems
      By nick E in forum Tech Discussion
      Last Post: 06-10-2010, 08:09
    4. Rover Motor running problems
      By matt100e in forum Tech Discussion
      Last Post: 31-12-2009, 15:55
    5. BBC running problems
      Last Post: 18-06-2009, 08:35
