paint question
Results 1 to 9 of 9
Thread: paint question
    Rods 'n' Sods Junkie vw2v8's Avatar
    wrexham
    395
    8
    vw2v8 is offline
    paint question
    just sprayed my lads bumper in base coat ,can i flat it befor aplying clear coat as these are a couple of bits of dust on it ,if so what grade paper do i use thanks
    The Camino Kid Britdragster's Avatar
    New Malden, Surrey.
    1,169
    145
    Britdragster is offline
    Re: paint question
    I would say it's ok to rub down. They call it colour sanding if memory serves me. It also helps remove any "orange peel" from the finish. I'm only going by what i've seen on tv. I would say start with maybe 1200 and go down from there and use plenty of water. I'm sure someone on here with plenty of experience will tell you the best way to go about it. Roger.
    Herts
    4,601
    198
    WB54 is offline
    Re: paint question
    depends what paint you're using but a grey scotchbrite pad will take most dust or dry overspray off and leave it keyed for clear.
    8,881
    1759
    blackpopracing is offline
    Re: paint question
    NO!
    If it's basecoat then flatting it will change the colour. If you flat it down then another coat of basecoat will need to be applied.
    You only need to leave it about 20 mins after basecoat before clear. You can flat the clear between coats no problem.
    ASH
    The returned ASH's Avatar
    Maidstone Kent UK
    190
    ASH is offline
    Re: paint question
    as above , nib out the crap and then dust a new coat over , leave to dull off then hit it with the clear .
    Color sanding as the yanks call it is when the flat the clear off before using a mop to bring the lustre back .
    we call it flat an polish , seen as thats what were doin ;-)
    wrexham
    395
    8
    vw2v8 is offline
    Re: paint question
    ok thanks just picked up a very fine pad to take out the dust...
    how soon after do you spray clear,or how long can i leave it before clear coat,can i leave it a couple of days b efore applying clear.coat thanks for all the help
    8,881
    1759
    Re: paint question
    Clear coat should be applied within a few hours. If you leave it 24 hours you will need to do another basecoat.
    As I said, clear can be added after about 20 mins.
    Rods 'n' Sods Junkie chewy's Avatar
    Jan 2010
    closer than you think
    133
    11
    chewy is offline
    Re: paint question
    Quote Originally Posted by vw2v8 View Post
    if you have dust in it you can get base coat tackrags wich are good ,, or flat with 2000 make sure its properly dry or it will tear , then put another coat of base over it ,,
    wrexham
    395
    8
    vw2v8 is offline
    Re: paint question
    thanks for the help and advise
    1. Name for this paint job
      By Parker in forum Chat
      Last Post: 28-01-2010, 20:24
    2. Glyptal Paint?
      By Gotzy in forum Tech Discussion
      Last Post: 11-12-2009, 12:40
    3. Paint Question-Chassis & Running Gear
      Last Post: 08-11-2009, 11:53
    4. paint question
      By nobody in forum Tech Discussion
      Last Post: 01-09-2009, 19:12
