performer rpm cam
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    prostreet enthusiast
    bromley kent
    195
    40
    chris-461 is offline
    performer rpm cam
    does anybody know if a performer rpm cam has a rough idle on tick over or a smooth idle ive just fitted one & i cant get it to stop souding like a pro mod.
    i have changed inlet gaskets & carb& im still having a job tuning.i am now at the point of giving up so if anybody might be able to throw some idea my way as to what to look for before i go completly bald.
    South West Essex
    4,093
    14
    Roscobbc is offline
    Have you tried advancing static timing?
    bromley kent
    195
    40
    i have advanced timing up to 16 b4 this is the only way we can get it to idle
    this all started with what we think was an air leak in the manifold because when the temp reached 200 it would rev to 1700 so removed inlet resealed gaskets but still had air leak seemed to be intermitant as you could here it every time the engine ran rough but now not sure where to go next.
    London Heathrowish!
    7,721
    46
    Plumpcars is offline
    Have you rebuilt the heads? Had them skimmed? If so the manifold may not be seating correctly and would give the symptoms you describe.
    489
    langy is offline
    I use the RPM cam most of the time in SBF's and find them slightly lumpy but tickover quite well, what engine do you have ???, Sounds like timing or a vacuum leak.
    Quote Originally Posted by chrismk4 View Post
    bromley kent
    195
    40
    Quote Originally Posted by Plumpcars View Post
    Quote Originally Posted by langy View Post
    did have the heads off but only to have valve stems turnred down for double springs. engine is 396 b/b chevy with closed chamber oval port heads originaly from 66 chevy chevelle.
    London Heathrowish!
    7,721
    46
    Could it be the cam giving a lower vacuum and maybe upsetting the power valve? You need to know the vacuum at idle and tune power valve accordingly.
    bromley kent
    195
    40
    already done that cam pulling about 10 so changed power valve to 4.5 as advised by man at customville.
    was wondering if valves were to tight would this make it idle rough & have a loud crackle trough the exhaust.
    Official RnS Addict Zody's Avatar
    Sussex
    1,771
    Zody is online now
    I have come across a similer problem before, my mate fitted a new cam & timing gears in his 454, ran like a bag of poo on tick over ?
    I decided to pull the timing cover, and found the bottom gear was in the wrong posistion, as the crank gear had 3 x posistions, he had set one that looked like a "O" but turned out to be a oblong square ! the gear line up was close to 2 x teeth out ...
    I'm not saying yours is the same .... but worth a check ????
    The car is open, the keys are under the dog !
    S.E London
    5,697
    510
    vince-305 is offline
    He's replaced the chain with gears and has double checked the position and they are correct
    Bit'z 'N' Piece's
    1. Edelbrock Performer manifold Rover V8
      By john64 in forum Stuff - FOR SALE
      Last Post: 05-05-2010, 11:15
    2. Edelbrock performer 750 cfm carb
      By trevd in forum Stuff - FOR SALE
      Last Post: 15-01-2010, 17:52
    3. Swap: Performer manifold for SBC Flywheel
      By Paul Y in forum Stuff - FOR SALE
      Last Post: 02-11-2009, 08:41
