Pinion angle
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 61
Thread: Pinion angle
    S.E London
    5,717
    513
    vince-305 is offline
    Pinion angle
    Whats the best pinion angle for hookin up ?
    In the consul i think i have too much as it wont spin the wheels
    (either that or not enough power)
    But it was starts to let loose half way through the rev range or was that due to the ladder bars ?
    Bit'z 'N' Piece's
    "call 0-800 Apocalypse" satan's Avatar
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Re: Pinion angle
    Quote Originally Posted by vince-305 View Post
    vince, i,m a bit confused mate, what is it you want it to do? spin or hook
    as for power,,, ask andy frost, he,s somewhat of an authority on power,[along wiv a few others] personally i dont think there is such a thing as to much power, its converting it to forward motion where the fun starts
    S.E London
    5,717
    513
    Re: Pinion angle
    Not loose traction at 3000+ revs while being floored through the gears
    Can you imagine losing traction at 1000ft with your foot buried
    Bit'z 'N' Piece's
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Re: Pinion angle
    so what your saying is the initial launch is fine with little or no spin then the car breaks loose, am i in the ballpark? ok as i never seen yer car[except in pics]i,m gonna ask some dumb questions,
    auto or manual,
    what engine,
    what sort of power you making,
    any gas, wild cam,
    what sort of axle, open/locked diff,
    are you still on ladder bars if so what lenth,
    is just one wheel breaking loose, or both,
    sorry for so many questions but me brain works in a kinda weird way, anything you think might be relevant, chuck it in the mix
    S.E London
    5,717
    513
    Re: Pinion angle
    Quote Originally Posted by satan View Post
    auto or manual,
    what engine,
    any gas, wild cam,
    And i thought youd know that and i would be on your list but if you having to ask then i must be ok for a lil while ..............
    No Spin (not even in the wet with nylon tryes)
    auto
    305 chev
    probably no more than 150
    350 cam
    9" open
    ladder bars 24" straight (as per leaf springs)
    im thinking 1 but too busy ****ting myself to know for sure (gets a lil squirely)
    Bit'z 'N' Piece's
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Re: Pinion angle
    right, so heres what i,m seeing, no offence vince,[you know i luv ya car right?] but were not talking a lotta horses here so therefore i think it yer rear end setup, i,m once again mystified as to 24" ladder bars, same as the springs? now ladder bars have 2 fixing points on the axle,and 1 to the chassis[usually somewhere up front, as you have a straight axle on the front i,de be looking at somewhere close to the rear spring mount of the front spring] **** i hope this all makes sense! normally with this setup youde be running coils, so not sure what youve got? can you clarify
    checked the list, your not on it.
    Last edited by satan; 05-04-2010 at 14:07. Reason: just to put vinces mind to rest.
    S.E London
    5,717
    513
    Re: Pinion angle
    When i made the ladder bars they were made to replace the leaf spring and use the front mounting location hence the length and the "as per" part of my reply
    Same as the springs the ladder bars mounted the axle in the stock location (now im getting confused )
    As you say, im running coil over spax at present with them wound right off or as hard as hell it makes no odds
    I know this sound really stupid but the reason for the original question was im replacing the "too short ladder bars" with something that i know will work (leaf springs) a step backward but more streetable than ladderbarswhen your as high as me
    And the problem lies with where you say not a lot of power this may/will be changing over the winter (funds allowing) and with the extra bit of uuumph id like to get it sorted now
    Make anymore sense ?
    Bit'z 'N' Piece's
    Official RnS Addict cabby's Avatar
    Surrey
    838
    34
    cabby is offline
    Re: Pinion angle
    Vince what ratio diff have you got??
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Re: Pinion angle
    yes perfectly understood now, and i have worked out the problem,
    1st off, the diff flange and the gearbox flange need to be parallel,[they can be different hieghts], imagine two straight lines one through the pinion and one through the crank,obviously the limits have to be governed by the u/j,s angle.
    2nd, ladder bars way too short,
    3rd,short[see above] ladderbars and high pickup point[chassis mount] will make for violent hookup to start with but will then there will not be enough load transfer to keep the tyres planted,hence squirrely at the top end,[ring any bells]
    4th, if you make them too long you get exessive tyre shake and body squat .
    the problem with ladder bars is they need to be adjustable for every situation,[somewhat a problem with our roads] this is possible on the strip,but nigh on im****inpossible just on any average road in the uk.
    so what we gonna do[answers on a postcard to vince305 c/o r"n"s
    me,,,,, i,d 4 bar or 4 link it, if your looking to improve power, get it to handle first,[cos i dont want you down here for a very long time]
    vince it ocoured to me if you go back to leaf springs i devised a very good traction bar setup that is extemely streetable,[i must learn how to put pics an drawings on this thing]
    S.E London
    5,717
    513
    Re: Pinion angle
    Quote Originally Posted by cabby View Post
    Only mile munching 2.75:1s Tone
    Have you ever seen "Bill n Ted's bogus adventure" where they most excellently beat Mr G Reaper
    Well thats how i feel Mr Satan (as you missed the part where i said i was fitting leaf springs)
    Any idea on the Best pinion angle for leaf springs .................... please
    Bit'z 'N' Piece's
  1. project angle box!!!
    By sickntwisted in forum The Garage
    Last Post: 21-08-2010, 20:58
  2. Ex-AA 2500kg Car Trailer with low loading angle
    By JAY PS in forum Stuff - FOR SALE
    Last Post: 12-03-2010, 22:29
  3. Correct angle
    By bootlegger in forum Tech Discussion
    Last Post: 25-02-2010, 12:06
  4. RHD rack & pinion
    Last Post: 04-10-2009, 11:13
  5. engine/box angle 350/350 chev
    By 100ev8 in forum Tech Discussion
    Last Post: 23-09-2009, 15:50
