Pinion nut
Results 1 to 3 of 3
Thread: Pinion nut
    Jul 2009
    WEST MIDLANDS
    1,593
    87
    CRAIG is offline
    Pinion nut
    I forgot to count turns whilst undoing pinion nut when I changed the seal,How critical is it and what to do next, thanks Stock 100e
    Herts
    4,565
    197
    WB54 is offline
    fairly critical in a new build but you can get away with it. Issue is the sleeve is already compressed, so tightening again without compressing further is difficult. Assuming you only changed the pinion seal and not the bearing, whack some RTV on the pinion spines and seat the flange (oil can leak down the splines). Second, clean the pinion threads with brake cleaner, apply red thread lock, spin the nut on, snug it up and only nip it with a small bar, rotate the flange 2-3 time check it doesn't tighten any more. Don't swing on it, just tighen as much as you can without resorting to excessive leverage. Stake the pinion nut to lock it in place. You "should" be ok but listen out for any rumbling or whining. alternatively pull it and set it up on the bench with a torque dial and new sleeve.
    Jul 2009
    WEST MIDLANDS
    1,593
    87
    CRAIG is offline
    Thanks
    1. Rover SD1 Pinion Extension or TR7 5 Speed Pinion Flange
      By fingers in forum Stuff - WANTED
      Last Post: 22-08-2010, 12:26
    2. Replies: 1
      Last Post: 23-06-2010, 18:25
    3. nut inserting tool/holesaws
      By jack earls in forum Stuff - FOR SALE
      Last Post: 28-04-2010, 10:59
    4. Spark plug retaining nut thread size
      Last Post: 11-04-2010, 10:04
    5. Nut on the wheel ?
      By kapri in forum On Topic
      Last Post: 19-07-2009, 19:14
