Pinto Help
Results 1 to 5 of 5
Thread: Pinto Help
    Feb 2010
    Easington Colliery
    29
    NaughtyMessiah is offline
    Pinto Help
    Hi guys hoping someone here can help me out with what should be a fairley simple thing, bought the pinto in bits and have re-built it just went to finish it today by putting the cambelt on, and its not the right one,, no problems i do have a correct one. Only thing is i now cant get the crank pulley off again. Ive used heat and a hub puller but all ive managed to do id bent the pulley bolt. Any help greatley appreciated
    S.E London
    5,697
    510
    vince-305 is offline
    Normally they get stuck on due to the water pump leaking straight on top of it but as you have only just put it together it should come off with the puller
    All i used to use was a pair if tyre levers behind it and lever them off in a rocking motion EVENTUALLY even the hardest ones would give with a tap of the hammer while levering
    Good luck
    Bit'z 'N' Piece's
    23,268
    If it's a Sierra Pinto then it normally needs a puller, if it's a double pulley it WILL need a puller.
    The problem with the tyre levers is that there is an awful lot of ali behind the pulley.
    Feb 2010
    Easington Colliery
    29
    Yep its the double pulley, think i'll give it a go with the pulley and try lever it from behind as well, if not might have to end up cutting it off.
    Feb 2010
    Easington Colliery
    29
    Nope even with me and me brother 40+ stone swinging off it it would budge so im gonna have to cut it off
    Cheers for the suggestions lads dont suppose any of you have a spare
    1. pinto piper 285 cam
      By movinghotods in forum Stuff - FOR SALE
      Last Post: 22-03-2010, 12:20
    2. pinto & 5 speed
      By 352 kum in forum Stuff - FOR SALE
      Last Post: 21-02-2010, 11:22
    3. 205 Pinto engine
      By kapri in forum Stuff - WANTED
      Last Post: 05-11-2009, 22:39
    4. Pinto ?
      Last Post: 01-11-2009, 10:56
