Pitman arms
Results 1 to 9 of 9
Thread: Pitman arms
    S.E London
    5,717
    513
    vince-305 is offline
    Pitman arms
    Would it be possible/feasible to swap/heat/cut the pitman arm
    Im guessing swapping wouldn't be an issue but would any one know of which box's use the same size spline/shaft diameter
    I dont like the idea of cutting but thought id throw that in the mix just in case it is doable
    Bit'z 'N' Piece's
    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    Thought you were talking about a pub !
    There's no replacement for displacement.
    S.E London
    5,717
    513
    Bit'z 'N' Piece's
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    I've cut both Pitman and steering arms, but never had a welded joint between the two ends as that would be too scary for me.
    The way I've done it is to shorten the arm and then build up each side of the arm with weld to form a decent size boss before boring a new tapered hole through the arm to take the ball joint.
    I've heated and bent steel steering components too, just make sure that you gradually heat the part, bend it without leaving sharp corners or reducing the material section through the bend and then let the part cool naturally.
    Would have thought that there'd be a number of Pitman arms that'd fit your box unless you have something unusual fitted now.
    Stuart.
    Hidden Content
    23,985
    The bigger question is why ? Don't forget that altering the Pitman arm will alter speed of steering and also ,in some case, reult in lost travel at ends of use and even going over centre and locking out so no steering return.
    What are you hoping to achieve as tehre may be better ways?
    S.E London
    5,717
    513
    Kev mainly for research as i would like to compile of list of what interchanges with what but also felt that i could lower the angle of the steering arm closer to horizontal rather than raise the opposite end
    I know that if you heat and change the drop it will decrease the length but if one was longer from an interchangeable vehicle if the drop was increased in theory it would/could end up at the same ratio
    Im confusing aint I
    Bit'z 'N' Piece's
    23,985
    ...and yet it's ONLY the car that has an ASBO?
    Banjo snapper. Hemi Bucket's Avatar
    Knocking one out.
    3,507
    998
    Hemi Bucket is offline
    Might be an idea to mention what box you have, how long its current Pitman is & how long/what shape you're looking for. A mate's just made a new Pitman by making an insert out of the splined end of a stock arm, tapered it, welded it into a new arm & then drilled between the join where the insert meets the arm & pinned it so if the welds on both sides gave up [how likely?] the pins will hold it.
    If it's a general swapabillity list, I know a split screen VW bus Pitman won't swap with a Bay.
    How'd the weekend go? Well, at the moment it looks like a dolphin that's been caught in a boats propeller.
    23,985
    I think you'll find that's spelled E bay Al ?
  1. Mustang pitman arm
    By Keith in forum Stuff - WANTED
    Last Post: 23-02-2010, 13:36
  2. Radius arms
    By Bumper in forum Tech Discussion
    Last Post: 11-09-2009, 12:27
  3. Wellington Arms Hotel this friday
    By 33speedster in forum On Topic
    Last Post: 29-07-2009, 20:10
  4. jag shafts and arms on Ebay
    By GlennC in forum Stuff - FOR SALE
    Last Post: 17-07-2009, 12:41
  5. mustang tci suspension arms
    By sd156 in forum Tech Discussion
    Last Post: 30-06-2009, 22:47
