poly bushing causing squeaking !
Results 1 to 9 of 9
    kro
    Rods 'n' Sods Junkie kro's Avatar
    Jul 2014
    surrey uk
    115
    16
    kro is online now
    Is it common for a front end that is poly bushed to creak and squeak quite badly..
    I understand there is a certain grease that should be used upon assembly....has anyone else experienced this
    cheers keith
    Cheers keith..
    12,628
    more common on the harder compound bushes but from memory silicone grease stops it. apply to the inner part of the bush and the steel inner sleeve.
    Herts. and ahead of Larry :)
    2,599
    34
    chevy2 is online now
    A lot of the poly bush kits come with a small sachet of silicone grease,
    Copper slip works just as well as it doesn't wash out with rain etc,
    Apply a liberal amount to the outer surface of each steel sleeve where it passes through the inside of the poly bush,
    If you've not done this yet the only fix is to pull each sleeve, grease and refit.
    You may be lucky as some kits have grease nipples to lube without stripping it down.
    Oct 2014
    Wiltshire
    268
    4potHemi is offline
    I didn't realise it was silicone - it's white in colour. As Chevy2 says "apply a liberal amount". Also to make sure you use regular grease on inside of steel sleeve to stop it seizing on bolt, but obviously keeping greases separate.
    kro
    Jul 2014
    surrey uk
    115
    16
    kro is online now
    Thanks for the replies guy's....I have some silicone grease here so it's just a matter of stripping the front end out, and deciding whether or not to re use bushes or replace them !
    cheers keith
    Cheers keith..
    Welding Guru
    Apr 2012
    Runcorn Cheshire uk
    412
    506
    30
    weldtech is offline
    One of the guys i know had the same issue and cured it by using white spray grease and just dumped half a can on the areas he suspected. It has done the trick for him without a rebuild.
    May 2015
    Birmingham
    310
    2
    drseg is offline
    silicon spray oil is good on suspension creaks too
    22,933
    The idea is that the inner sleeve should be clamped by either mounting bracket and the bush be able to rotate around it.
    Sometimes the bushes need fettling to stop them being being jammed in position due to being too thick.
    2,599
    34
    Yes Kev, although you grease the sleeve etc correctly the top hat part part is sometimes a bit oversize and rubs against the outer chassis brackets and that area may squeek until it wears down,
    If you notice the outside faces of the bushes fouling against the brackets on assembly then apply a dab of grease there also.
