Pop axle & anglia hubs-bearing question
Results 1 to 7 of 7
    Rods 'n' Sods Junkie Hole Shot Pop's Avatar
    St Austell, Cornwall
    218
    Hole Shot Pop is offline
    Can someone give me a definitive answer please on the inner and outer wheel bearing combo when putting anglia hubs on to pop spindles for a disc conversion? Also, I've heard that a spacer is required to make this work. Can anyone confirm? Thanks guys
    23,876
    I can't give a definitive on the Anglia hub but you certainly have to make a spacer on the Herald conversion.
    Birmingham
    5,795
    57
    40Stude is offline
    Check out this page on Martin Holden's web site. Vented discs onto a Pop axle.
    http://www.flatheadv8.freeserve.co.uk/martsframes.htm
    Jul 2009
    Yeovil, Somerset
    1,769
    822
    Stroprock is offline
    Ditto. I not sure if an anglia conversion requires spcers at all actually, since I heard it is 'Bolt on', but with a Triumph conversion you do need a spacer, and the bearings need swapping (I think it is Pop inners, Triumph outers). The Wheel bearings could well be the same combo, only not using the Triumph but the Anglia bearings.
    218
    Thanks for that. This is taken from Marts page "Outer bearing same as Pop. Inner bearing different on Anglia, but Pop bearing is same series, and is a direct swap." At the risk of sounding stupid, can I ask what "the same series" is? If the outer bearing is the same for the anglia and pop, and you have to use the pop inner bearing surely it's easier to get a pop inner & outer? Or am I missing something? Thanks guys
    northumberland
    2,670
    sqweaka is offline
    new bearings are available that are a mix off the pop inner and the 105e outer halfs that allow you to fit the 105e hub to the 103e spindle! the part number you ned for the new bearing is 07098 07210X. got mine from my local bearing supplier for £17.50 each
    218
    Quote Originally Posted by sqweaka View Post
    Thanks very much, that simplifies things. Cheers
  1. Ford Pop front axle & hubs
    By THE POP SHOP in forum Stuff - WANTED
    Last Post: 06-05-2010, 15:33
  2. Replies: 8
    Last Post: 04-01-2010, 08:24
  3. anglia 105e rear axle wanted
    By crumble in forum Stuff - WANTED
    Last Post: 06-11-2009, 17:17
  4. anglia 105e axle
    By Frenchy in forum Stuff - WANTED
    Last Post: 13-10-2009, 05:40
  5. Ford Anglia 105e front hubs £15 pair
    Last Post: 03-10-2009, 23:29
