possible overheating issue updated
Page 1 of 9 1 2 3 ... LastLast
Results 1 to 10 of 83
    Aug 2009
    braintree
    14,069
    69
    Darren West is offline
    ive had my truck running for about 12 mins at a guess
    the temp gauge reads 92 and the pipes seem to be under pressure
    there is no fan connected to the water pump pulley at the moment
    do i have issues with the possibility of a head gasket issue of is this normal for that amount of running time
    engine is a 305 small block chevy 1990
    thanks
    Rods 'n' Sods Junkie bunj's Avatar
    Apr 2012
    Peterborough
    161
    39
    bunj is offline
    My 305 hits 85/95 within that time scale with no problems. Fresh build though so still waiting for snags.
    Aug 2009
    braintree
    14,069
    69
    the hoses seem quite hard also at that temp?
    thanks for your reply
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Sorry to answer a question with more questions, but a bit more information would help.
    Is your temp gauge sensor in the stock position in the cylinder head?
    Does the rad feel really hot, fairly hot, or coolish when you get the 92 degree reading?
    Do you still have the stock thermostat installed?
    Stuart.
    My Intro
    Aug 2009
    braintree
    14,069
    69
    thanks for helping mate
    ok the temp sensor is in the radiator
    yes its far too hot to touch
    i think it does have the std thermostat still installed
    i do have 1 of these spare if you think i should install it
    the metal fan would be 35mm from the radiator
    i do have a 14"fan mounted 10mm from the rad on the other side controlled by a adjustable temp switch and a override in the cab
    thanks
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    The std thermostat in a late motor is quite likely to be 85 degrees C or thereabouts, so when the water does hit the rad it is going to be hot, with no engine driven fan it's going to get hotter when the truck is standing still; I wouldn't worry unless the electric fan doesn't knock the temperature back when it does cut in..
    Stuart.
    My Intro
    Aug 2009
    braintree
    14,069
    69
    i can't fit that fan as it will hit the bottom rad hose
    should i loose the stat i don't have a heater in the truck
    ill remove the rad and see if i can get the elec fan right up against the radiator
    just after seeing all those motors yesterday overheating I'm a bit paranoid
    Official RnS Addict stu460's Avatar
    Jul 2011
    Cheshire
    1,783
    66
    stu460 is offline
    Keep the stat. If you remove it all it does is make the engine take longer to get up to temp as you're heating the water in the rad as well as the engine. It will still get hot, just take longer.
    Why is the temp sender in the rad? Until the stat opens you won't get a true temp reading.
    The rad feels hot because it is hot! The water hitting it is at 85 degrees, your body temp is 37. I have always found that the rad hoses feel hard when the engine is hot. They're pumping water under pressure. Are they soft when the engine is stone cold, even when running initially?
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Personally I wouldn't rush to remove the stat, if you really want to, just cut out the centre section, and leave the rest in place; you need some restriction to make the the water circuit work correctly.
    Running with a stat shouldn't be problem as long as you have enough cooling capacity, you would get better engine power (if that's important to you) by changing to a 70 degree stat.
    Not having an engine driven fan isn't a problem as long as your charging system produces enough power for a decent electric fan; I have a 16" fan in front of the rad in my truck, you can almost see the needle move on the temp guage when it cuts in, but it does take 20A running and nearly 30A on cut in, so it's well worth having a relay in the thermostatic switch circuitry if you have a big fan.
    Stuart.
    My Intro
    Dec 2011
    Norfolk
    259
    Smokey is offline
    SBC normal temp is 180f (90C)
    Remove a coupe of plugs and have a look at the colour.
    1. Starter Motor Issue Help please!!
      By USACUSTOMS in forum Tech Discussion
      Last Post: 23-06-2013, 10:58
    2. more sbc and th350 help please..... pretty please
      By MrtsCOE in forum Tech Discussion
      Last Post: 20-02-2012, 22:04
    3. help please sbc, wont turn over , what have i done
      Last Post: 27-12-2011, 18:45
    4. SBC Engine mount help please
      By captainsmelly in forum Tech Discussion
      Last Post: 31-03-2011, 22:16
    5. Help please folks !!
      By andy fadster in forum On Topic
      Last Post: 06-07-2009, 19:17
