up date on power steering, I asked on here options on light steering on my chevy suburban, it is running jag front clip with sd1 rover power rack with
buick v6 (monty-carlo) power pump, had a lot of responce, but thought before doing anything else I would try a sd1 power pump, in theary it should
work right as they will be suited to each other , well got pump and set it up and it is now a bit heavier on steering, I am now not woried that the old
biuck pump will bugger up the rack seals, so thanks again for advice, cheers Richard.
