Problem with Mcleod rover v8 10.5 clutch set up
Results 1 to 9 of 9
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Willys V8 is offline
    Hi folks,
    Fitted a mcleod 10.5" clutch plate and cover to my rover v8 sd1, with ttv lightened flywheel, now it's become so differcult to engage gears and clutch feels like it's dragging?
    I previously ran the ttv flywheel with a heavy duty nelix 9.5" clutch plate and standard cover with no problems.
    I read on the mcleod website that their plates take around 500 miles to bed in but I didn't expect things to be this bad?
    Everything was fitted spot on, clutch fork etc aren't that old and in excellent condition so I'm a bit stumped as to what the problem is?
    Any help much appreciated.
    Cheers.
    kent
    3,002
    choppedblownpop is online now
    When I ran my 10.5 Mcleod,(double plate) it needed 2" of free play at the pedal,mine didn't need bedding in.
    I've gone from a Mcleod to a sintered bronze double paddle clutch,I had to go down two sizes on the mastercylinder,as the pedal was too hard.You may have to play with different slave cylinders,(rover made 3 sizes) to try and get a decent pedal
    Sent from my iPad using Tapatalk
    Apr 2012
    Ystalyfera S. Wales
    161
    daxcobra is offline
    Check how much throw(movement) you are getting on the pushrod, sounds like it's not disengaging. Dave
    May 2016
    S E London
    1,001
    22
    timbo56 is online now
    Have you got enough movement on the pedal to fully release the clutch, I had a similar problem with a part worn Mcloed clutch where the (racing) centre plate was quite thin and the cover fingers needed a lot of movement to fully release it. I've fitted a standard clutch which has a far thicker centre plate and it's now fine.
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Can I just ad the pedal is easy enough to push down on and everything was fine with my previous set up.
    May 2016
    S E London
    1,001
    22
    Quote Originally Posted by Willys V8 View Post
    But you've fitted a new clutch so everything is different now.
    kent
    3,002
    Undo your slave cylinder,put a couple of washers between slave and bell housing,do bolts up,this will give you approx about an inch of play at pedal
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Ok cheers. I'll give that a go. I'll let you know how I get on. Thanks again.
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Thanks choppedblownpop , works a treat. Cheers bud.
  1. Clutch problem with the pedal ford Folcon
    By fordf350camper in forum Tech Discussion
    Last Post: 04-08-2017, 22:34
  2. Interesting problem with my RV8 ?
    By Stevie G in forum Tech Discussion
    Last Post: 10-04-2012, 23:31
  3. problem with my pm's
    By stevie.t in forum Chat
    Last Post: 20-02-2012, 10:57
  4. problem with estas.....trip to the US
    By TOETAG in forum On Topic
    Last Post: 14-10-2011, 21:33
  5. Tyre gurus,do I have a problem with?
    By kripfink in forum On Topic
    Last Post: 11-11-2010, 10:48
