prop phasing and vibration
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
    Aug 2009
    braintree
    14,082
    69
    Darren West is offline
    i still have a vibration from 48mph upwards and gets worse the faster i go
    i have jacked up the back of the truck and removed the wheels then sat it on axle stands
    the vibration is still there
    this is speed related and not engine related because at the same engine speed in 1st and 2nd the vibration is not there
    i did have a huge vibration issue 4-5 months ago but this was a knackered u/j
    i have purchased a digital angle gauge and these are my findings
    i don't really understand angles and phasing even after reading about it
    so can some clever person tell me whats wrong and what i need to alter to fix it
    thanks
    Jun 2015
    Afghanistan
    329
    stevieturbo is offline
    Is the shaft good ? ie balanced etc correctly ?
    Installed correctly ? not binding up or anything ? ie slip joints wherever they are needed ?
    Aug 2009
    braintree
    14,082
    69
    yes yes yes and yes
    its a new shaft balanced
    only slip going is in the box as std
    Aug 2009
    braintree
    14,082
    69
    what I'm reading is should be a 1 degree downward angle on the gearbox but up to 3 degrees downward angle
    and the same on the pinion shaft ?
    so it should be ok where it is then ?
    Official RnS Addict ANDY S's Avatar
    Aug 2009
    Tonbridge Kent
    544
    66
    ANDY S is offline
    Hello Darren just a thought have you checked the flanges on the diff & the gearbox ? I had this problem years ago that turned out to be the flange on the diff just a thought atb Andy.
    Aug 2009
    braintree
    14,082
    69
    stuee on here totally rebuilt the whole rear axle and the only thing he noted was 1 of the shafts was 4 tho out but apparently this is nothing at all
    Glasgow,Scotland
    2,123
    german8rcoupe is offline
    Wrong.....rear of box should be pointing down by anywhere between 1-3 degrees (to get carb level it will be nearer 3), rear axle flange should be pointing up by the same amount as the box is pointing down...i.e: equal, but opposing angles.
    If you habe both pointing down just now then the prop may "whip" like a skipping rope and do in the u/j pretty quickly.
    Aug 2009
    braintree
    14,082
    69
    looking at my arrows they show the way that the angle is pointing
    so I'm right ?
    Glasgow,Scotland
    2,123
    You have arrows pointing up and down....????
    Does pinion point up?....it should....
    Does box tail shaft point down?....it should...
    Aug 2009
    braintree
    14,082
    69
    yeah they point towards each other
    1. helppp please short bit of prop end and diff flange
      By sidewaysbo in forum Stuff - WANTED
      Last Post: 16-11-2015, 20:54
    2. ford 2000e gearbox prop end and gearstick
      By popmad in forum Stuff - WANTED
      Last Post: 06-08-2014, 21:30
    3. prop shaft and new RV8 camshaft
      By crozch in forum Stuff - FOR SALE
      Last Post: 01-03-2013, 22:29
    4. Teardrop lights, prop, tools and stuff
      By russ6120 in forum Stuff - FOR SALE
      Last Post: 04-01-2013, 21:27
    5. Replies: 3
      Last Post: 02-06-2010, 18:02
