Proportioning valve
Results 1 to 8 of 8
    Nov 2011
    suffolk
    6,075
    1430
    russ6120 is offline
    Proportioning valve
    I'm getting ready to get the brakes all sorted on the panel van and my mate Tom was banging on about how I need a proportioning alive for the rear.
    I have drums on the rear and discs up front. Can someone explain why I need such a valve if my master cylinder is for disc/drum anyway?
    Russ
    I'm a grown up member now ! Justboy's Avatar
    Jun 2016
    Ayr
    88
    Justboy is offline
    Whether you need a proportioning valve or not depends on whether the master cylinder was designed for the relative displacement of fluid front/rear. But what you will need is a residual pressure valve for the rear otherwise there will be too much travel in the wheel cylinder pistons.
    12,922
    Quote Originally Posted by Justboy View Post
    Only if the master cylinder is lower than any of the calipers or wheel cylinders.
    Rods 'n' Sods Junkie redoxide1974's Avatar
    Apr 2012
    Dorset
    420
    70
    redoxide1974 is offline
    If the MC is mounted below the floor it may also be lower than the wheel cylinders. When the brakes are not in use the fluid will travel back to the MC if you haven't got residual valves. You will then have to pump the brakes to 'charge' the wheel cylinders.
    By fitting residual vales, the valves keep the wheel cylinders 'charged' with fluid and stop the fluid draining back to the MC so as not pump the brakes each time.
    I don't think they are needed if the MC is mounted on the firewall.
    Its also worth fitting a proportioning vale to the rear line to control the brake split/ballance.
    Nov 2011
    suffolk
    6,075
    1430
    russ6120 is offline
    Call me dumb but isn't the point of using a dual circuit mc so to get the correct amount of fluid going to all the right places?
    Aug 2009
    braintree
    14,069
    69
    Darren West is offline
    your dumb
    ha ha ha ha
    Sep 2011
    Fareham
    1,227
    normalbloke is offline
    Quote Originally Posted by Darren West View Post
    your dumb
    ha ha ha ha
    *you're.
    12,922
    Quote Originally Posted by russ6120 View Post
    no it's so if you have a leak somewhere you still have 'some' brakes
    1. Brake bleeding gm proportioning valve
      By 24v in forum Tech Discussion
      Last Post: 25-03-2015, 16:56
    2. AP Racing proportioning valve
      By choppedblownpop in forum Stuff - FOR SALE
      Last Post: 20-10-2014, 13:13
    3. Wilwood master cylinder and proportioning valve - BRAND NEW
      By Chris289 in forum Stuff - FOR SALE
      Last Post: 26-08-2014, 12:08
    4. Chevy Brake Proportioning Valve
      By Dr Strangelove in forum Stuff - FOR SALE
      Last Post: 18-09-2013, 00:38
    5. Brake proportioning valve & M/C help required!
      By Marc in forum Tech Discussion
      Last Post: 21-09-2011, 11:38
