Propshaft
Results 1 to 5 of 5
Thread: Propshaft
    Jan 2011
    GLOUCESTER
    891
    29
    nikb is offline
    Propshaft
    My propshaft on a bmw set up has 2 shafts with a middle rubber bearing, this has one shaft with a male spline going through the rubber bearing thing, the other end has a threaded nut under this is a internally splined plastic sleeve that buts upto the metal internal spline inside the propshaft.
    Now I'm guessing this is to either quieter the shafts as they slip together or to keep dirt out, the shaft is too long by 1cm ish, if I remove the nut and the plastic sleeve it's got plenty of slack now can I shorten the nut and cut the plastic down (about half it's length) reassemble and use it like that
    This propshaft assembly is used between engine and diff which are both fixed so don't require a slip joint, what do you guys reckon???
    Sep 2014
    Newcastle upon Tyne
    747
    368
    Ian34 is offline
    I'm no expert, but worth a go I think.
    Jan 2011
    GLOUCESTER
    891
    29
    nikb is offline
    Well on your advice Ian (well you were the only one) I've shortened the plastic and put it back together and it looks ok, the proof is when it's driving.....
    I'm a newbie !
    Mar 2011
    pontefract
    4
    st285 is offline
    i work for a propshaft company the plastic seal is to keep out the dirt. it also clamps on to the spline to remove any play when tight. install the prop then nip the nut up and it should be ok .check the small arrows line up that should be stamped on the two mating parts. sometimes you have to tension the rubber on the bearing by pushing the bearing forward and nipping the bolts up . hope this helps
    Jan 2011
    GLOUCESTER
    891
    29
    nikb is offline
    Cheers for the extra info, prop is all done now, just waiting for the paint to dry
    1. propshaft shortening
      By 58 delray in forum On Topic
      Last Post: 08-10-2014, 16:57
    2. propshaft yokes
      By Taff in forum On Topic
      Last Post: 21-02-2010, 21:16
    3. Wanted Morris Marina Propshaft?
      By kidmorris in forum Stuff - WANTED
      Last Post: 26-10-2009, 07:37
    4. 9" propshaft end
      By Tuggy in forum Stuff - WANTED
      Last Post: 21-09-2009, 22:57
    5. propshaft.
      By fordsondan in forum Stuff - FOR SALE
      Last Post: 22-08-2009, 21:16
