Rack and Pinion swap?
Results 1 to 6 of 6
    I'm a grown up member now ! King Kees's Avatar
    Oct 2013
    Purmerend, Netherlands
    61
    35
    King Kees is offline
    Hi there!
    I've got a leaking Jaguar rack and pinion, put in new seals and rings but that won't solve the leaking
    My question:
    Is there a rack and pinion that could be used instead of the rack & pinion from Jaguar?
    So swap the whole rack & pinion for another brand, such as Ford or something else?
    Something with a liitle work that would the job.
    Anybody did such a swap?
    I've read that the Jag items are prone to leak....
    I thought swapping for another should solve the problem and maybe some better available parts.
    This rack & pinion sits on a subframe from a '86 Jag XJ12 and is welded under a '59 Chevy Apache....
    Hope to get some tips before I have to hunt for a new rack....
    Thanks!
    Cheers, Kees.
    Kool Guyz CC
    1959 Chevy Apache Fleetside (for sale.....)
    23,476
    Rack has to be mounted in the correct place , with a set length between inner balljoints ( not track rod ends ) for all suspension to work correctly. You can succesfully fit another rack that is th same outer length but it will normally drive like crap.
    Official RnS Addict Phunkie Hiboy's Avatar
    Lindford
    1,014
    Phunkie Hiboy is offline
    Have the rack rebuilt by a reputable company. The company I use, for these racks, rebuild and give a years warrantee. Have been using them for years and never had a problem even after the warrantee ran out.
    Don't have their details here, they're at the shop. Won't be back there 'till Monday. Oh, and they turn them round in 3 days, maybe a bit longer outside the UK.
    Built without compromise by the more luck than judgment method
    Oct 2013
    61
    35
    Okay, thanks guys!
    Rebuild mine is an option.
    What years Jaguar uses the same steeringracks?
    This is from a series III.
    Is the XJ 6 and XJ 12 the same rack?
    And when do we call it a XJ40?
    That makes searching a lot less difficult if we have more options....
    Cheers, Kees.
    Kool Guyz CC
    Lindford
    1,014
    As you say XJ6/12 series 1, 2 and 3 and XJS
    Oct 2013
    61
    35
    Hard to find one overhere.
    Does the rack from a 1996 Sovereign fits?
    There two of them around.
    Or what has to be done to make it fit?
    Also can you unconnect the speedsensor without trouble?
    Cheers, Kees.
    Kool Guyz CC
    1. Rack and pinion
      By Iggy in forum Tech Discussion
      Last Post: 17-10-2013, 19:04
    2. Ford Rack and pinion for ex. + looking for 9" rear axle.
      By fede_fly in forum Stuff - WANTED
      Last Post: 15-06-2011, 18:39
    3. Rack and pinion widths
      By Adey in forum Tech Discussion
      Last Post: 23-02-2011, 16:16
    4. 57 Chevy rack and pinion steering
      By series1 in forum Stuff - FOR SALE
      Last Post: 14-02-2011, 20:57
    5. New - Mustang 2 rack and pinion - £180
      By Jon Connolly in forum Stuff - FOR SALE
      Last Post: 12-09-2010, 13:02
