Rad height
Results 1 to 3 of 3
Thread: Rad height
    S.E London
    5,697
    510
    vince-305 is offline
    Rad height
    At which height should the rad be mounted ........ The cap is on the rad should that be higher than the thermostat housing or would it be ok to mount it lower but have a remote filler at the stat housing
    Bit'z 'N' Piece's
    23,272
    The best position is the cap a minimum of a 2 hoses thickness above the stat .( leaves room for expansion within the tank ). If you mount the rad lower then you will need a filler plug on the rad plus an expansion pipe linked up to overflow tank , with staggered pipe heights within it , and back to 'stat filler neck.
    S.E London
    5,697
    510
    Cheers Kev.
    Bit'z 'N' Piece's
    1. Flatty crank, ally rads, mufflers etc etc.
      By originals in forum Stuff - FOR SALE
      Last Post: 16-07-2009, 09:35
    2. Shock Absorber Length @ Ride Height?
      Last Post: 09-07-2009, 14:00
    3. What size rad ?
      Last Post: 03-07-2009, 22:31
    4. mk 2 jag rad
      By sd156 in forum Tech Discussion
      Last Post: 02-07-2009, 22:22
    5. Rad!
      By Throttledwife in forum Stuff - WANTED
      Last Post: 02-05-2009, 23:46
