range rover gearbox/dont need transfer case. What are optiona
Results 1 to 6 of 6
    Official RnS Addict digger's Avatar
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    Hi All, I'm sure this has been done by someone?
    The Humber project I am helping on will have a rover 3.9 from a range rover, this is coming complete with the gearbox/transfer case.
    Obviously the humber is not 4 wheel drive so dont need the transfer box bit.
    What are the options for
    a] remveing the transfer box and adding a tail houseing from some other box??
    b] fitting another gearbox that will fit. [must stay auto]
    cheers guys in advance
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    easier to find a rwd box and sell the 4x4 one
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    A couple of things here, yes you can use the box but you will need the tail housing section of a zf jag box with the speedo drive which means hunting out an early xj40. You will also need the short bit of prop and the flange for the box. Range rover box has the tailshaft already drilled to accept the shaft extension for the transfer box so just unbolt that . Even if you found a complete jag box you will still need lots of bits off the rangerover set up.
    Bob
    I onlay edet to korrect bad smeeling mistaces
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    When I had my last breakers yard, I used to be inundated by offroaders using rangies buying xj6 auto boxes off me. apparently its quite easy to convert to them. could be an easy solution for you.
    Jan 2011
    GLOUCESTER
    891
    29
    nikb is offline
    You need the front bell housing and torque convertor off the gearbox and then as "street fighter" says you need a box from a jag, it's a zf4hp22, and get the cables/shifter/oil filler and dipstick, got it all for £150, or if your going manual I have everything here, to mate up with a rover v8
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    I would keep the R/R box for a few reasons. The cam inside the box on the end of the kickdown is cut to suit the engine characteristics, the 3.9 R/R box will have the beefed up forward clutch, the gearbox is on the skew in relation to the engine and the R/R deep pan A. holds more fluid and B. is shaped to correct this, the R/R box has a different 1st gear ratio to the jag unit which is lower. It would be better to just rob the few bits off the jag box that you need to get a prop set up and speedo drive .
    Bob
    1. range rover off roader
      By rangiemadbarney in forum The Garage
      Last Post: 19-02-2010, 18:27
    2. old range rover
      By rangiemadbarney in forum Vehicles - WANTED
      Last Post: 15-02-2010, 20:06
    3. range rover any condition
      By rangiemadbarney in forum Stuff - WANTED
      Last Post: 14-02-2010, 22:47
