Rover man gearbox advice..please
Results 1 to 10 of 11
    Official RnS Addict insanityvans's Avatar
    Nov 2009
    In a BIG pile of sawdust
    6,728
    3133
    384
    insanityvans is offline
    I have an auto gearbox on my P5B Rover V8 engine and am seriously thinking of changing it for a manual one. Any thing I should look out for? Will any Rover V8 manual box fit? And other sensible questions that I should ask.
    Thanks
    Cha7z
    Creator of fine sawdust from solid wood!
    Jun 2009
    1,829
    v8ian is offline
    Re: Rover man gearbox advice..please
    IIRC there should be no problem with the swapover, BUT only if you use the 2wd stuff, try usng the 4wd bits and it turns into a minefeild.
    Nov 2009
    6,728
    3133
    384
    Thanks Ian. That's good news. So, any Rover V8 Car manual box will be good for my engine!
    Thanks again,
    Cha7z
    Jun 2009
    1,829
    v8ian is offline
    I ran a LT77 behind a modified p5/6 engine for ages
    Nov 2009
    6,728
    3133
    384
    What is an LT77 and are they easier to find? And, how hard to fit?
    Jun 2009
    1,829
    v8ian is offline
    LT77 is the run of the mill Rover 5 speed, found in a few cars, Sdi, TR7s TVR wedges, Morgans, Sherpas, any thing really fitted with a RV8, 99% of all 2wd 5 speeds from BL, Other wise the 5 speed is found on all non V8SDIs apart fron the 2.0, which sometimes had 5th gear blanked off, Sherpa boxes have a short 1st gear and a cast iron remote, Jags have a short ally remote, but they have an odd bellhousing which needs to be changed, I have even seen the box fitted to a Moris Ital, MGRV8s have a R380 box, which is a upgraded LT77, you will be unlikely to find one of these,
    Later TVRs and Morgans were fitted with the R380, and also the BorgWarner T5
    Might be a helpful link, http://www.v8forum.co.uk/forum/viewtopic.php?t=2028
    The whole site is unintentionally biased towards to RV8
    Nov 2009
    6,728
    3133
    384
    That is really great info, thankyou. You can see why I asked for help!!! I have the chance of a manual box (still attached to the engine, which is being sold seperately) complete with clutch etc. Presuambly then, the gearbox complete with bellhousing, torque converter and clutch is a direct bolt on?
    I will have a look at the link you sent.
    Again, thanks
    Jun 2009
    1,829
    v8ian is offline
    The only thing you may need to get is a crank spigot bearing for the nose if the input shaft to sit in, prop wil need to have a seperate slip joint as the gearbox has a flange rather than a spline, Im not sure what your auto box has
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    throw a chevy v8 engine and box in ,you double the horse power and the spares are 1/2 price it's an easy swop they drop straight in, done in a triumph herald.
    Nov 2009
    6,728
    3133
    384
    Quote Originally Posted by paul67 View Post
    That is tempting!! But funds are limited and I'd like to be able to say the car is all British if/when it's done! (I know, the Rover V8 is actually a 215ci Buick!!!)
    1. I am looking for a 5 speed rover SDi gearbox if any one can help
      By gasser consul shane in forum Stuff - WANTED
      Last Post: 21-04-2010, 10:24
    2. rover v8 gearbox
      By Fad T in forum Stuff - WANTED
      Last Post: 09-03-2010, 19:13
    3. Rover manual 5 speed gearbox
      By martin56 in forum Stuff - WANTED
      Last Post: 24-02-2010, 19:56
    4. Rover P6 Gearbox question
      By matt100e in forum Tech Discussion
      Last Post: 08-08-2009, 09:32
    5. Jacking Up a Rover P6- Advice Needed Please!
      By Street in forum Tech Discussion
      Last Post: 23-06-2009, 18:52
