Rover SD1 V8 Auto Starter Motor question...
Results 1 to 7 of 7
    Rods 'n' Sods Junkie fingers's Avatar
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    Morning all, I have a Rover SD1 engine that requires a new starter motor. I know that if I was to be using the SD1 exhaust fannymoulds I would have to buy a SD1 starter motor due to the solenoid location, but I am using Landrover headers so can I fit a landrover starter motor or are the bolt holes different?
    Thanks in advance.
    May 2011
    Sussex
    236
    53
    specialshoe is offline
    depends on the gearbox - I have an SD1 with a BW65 and it needs a SD1 starter to work - Range Rover bolts up fine but you spin it and it wont engage on the ring gear - guessign range rover has bigger ring gear. - thats my limited knowledge.
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    Well thats a bit of a ****er, I was hoping any ol RV8 starter would do.
    Never mind, cheers for the response.
    Jul 2009
    Yeovil, Somerset
    1,761
    816
    Stroprock is offline
    Quote Originally Posted by fingers View Post
    I thought so too
    I fitted a P38 starter to my P6 engine no trouble. Works fine.
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    Odd? Is yours a manual or auto?
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    All RV8 ring gears are the same diameter whether it's fitted to a flywheel or an auto flex plate.
    The starter bolts to the engine block so gearbox type makes no difference.
    Provide the chassis or exhaust clears the starter and solenoid then you can fit either type of starter.
    However, the later starters DO NOT have a connection for a ballast resistor but this problem can be overcome by the use of a relay.
    Regards Denis
    Mar 2010
    Rivenhall, Essex
    496
    64
    fingers is offline
    Ace, thats what I needed to know.
    Cheers
    1. Rover sd1 v8 skinny starter motor
      By V8 POP in forum Stuff - WANTED
      Last Post: 21-03-2013, 22:01
    2. Wanted - Rover V8 starter motor SD1
      By n1tr0_9 in forum Stuff - WANTED
      Last Post: 19-02-2013, 17:55
    3. wanted, rover sd1 2.6 litre starter motor
      By patricklambert in forum Stuff - WANTED
      Last Post: 20-01-2013, 15:33
    4. Rover SD1 ign. question ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 05-09-2009, 15:25
    5. Rover v8 starter motor...
      By ThomasHarris in forum Stuff - WANTED
      Last Post: 23-07-2009, 19:26
