Rover V8 In Ford Pop - Engine mounts??
Results 1 to 10 of 12
    Apr 2015
    Auckland, New Zealand
    41
    50
    Garryg is offline
    Reaching out to those that have put a V8 Rover in a Pop. I am fitting mine at the moment. It currently has the SD1 mounts on it. Unfortunately it does not sit low enough and the mounts currently sit on top of the chassis. SO question is....how did you get your sitting lower? Did you cut and narrow the engine brackets, replace with something else, or make something to suit? Pictures would be great to visualise what you done.
    CHeers
    Leicester
    5,697
    594
    bigyellataxi is offline
    Garry, show us some photo's of yours, then we can assess and help...
    Hidden Content
    Fueled by Jim and Luckies.
    kent
    3,002
    choppedblownpop is offline
    Apr 2015
    41
    50
    Garryg is offline
    If you look at pic #2 you will see that the oil filter is close to the steering shaft. The only way I can clear this and get the engine lower is pus the engine back?? I'll be driving with the engine and gearbox in the car :-) With the engine in this position, the sump is about 280mm from the ground..... it looks quite high??
    kent
    3,002
    Put a remote filter on it !
    May 2010
    luton bedfordshire
    1,660
    gazzmyster is offline
    remote oil filter or smaller shorter oil filter
    May 2010
    luton bedfordshire
    1,660
    don't forget to allow for weight of engine on chassis it will go lower when off jacks etc,made that mistake sump was quite low then had to lift up.
    Turbo 4 pot freak 20vT_pop's Avatar
    Oct 2010
    Suffolk
    1,891
    1249
    20vT_pop is offline
    Set the car up at the correct ride height depicted by correct suspension angles then check the engine height and don't forget to check the height of the diff flange, also you can bias the engine to the left of the center line when mounting in the chassis if you need a touch more clearance as long as the centerline of the engine is mounted parallel with the centerline of the chassis longitudinally that will keep the propshaft phasing correct in that plane. Then you only have to optimise the horizontal phasing of the engine to diff flange.
    John
    My Pop Build thread Hidden Content
    My 55 Chevy Resto Hidden Content
    Anyone can drive a fast car, not everyone can drive a car fast!!!!
    Apr 2015
    41
    50
    Garryg is offline
    Quote Originally Posted by 20vT_pop View Post
    John
    Cheers All, I going to take the front end off this week at set it on blocks at the ride height I'm looking for. I'll go with the remote filter as this will give plenty clearance at the steering side. I've also started another thread for steering set-up :-)
    I just need to keep in mind this is a slow process.....I get frustrated when things don't go fast :-)
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    If you need a remote filter set up I've got a brand new advance adaptors one for sale, asking £75 for it. Fully kit with fittings and mountings
    PM me if you're interested
  1. Ford Pop engine
    By Jamesb in forum Tech Discussion
    Last Post: 18-08-2014, 17:19
  2. ford pop engine 1172cc and gearbox
    By Mango man in forum Stuff - WANTED
    Last Post: 26-07-2013, 15:51
  3. ford 302 engine mounts
    By 36dodge in forum Stuff - WANTED
    Last Post: 06-09-2012, 07:07
  4. Ford headers & Rover engine mounts
    By bigdavy in forum Stuff - FOR SALE
    Last Post: 05-02-2012, 22:07
  5. fitting a chevy engine into a Ford Pop
    By julietagg in forum Tech Discussion
    Last Post: 01-03-2011, 19:47
