rover v8 preload
Results 1 to 4 of 4
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Willys V8 is offline
    rover v8 preload
    Okay I know how to set preload apart from the question, do I tighten rocker arms down and then push up pushrods to insert feelers gauge or wire of correct thickness, between 20-60 thou seems to be the general consensus, or if not what is the best, easiest way? Cheers.
    Herts
    4,616
    224
    WB54 is offline
    yes but if you have a higher lift cam you might run out of adjustment without using rocker pedestal shims
    23,462
    When I did my last Rover I used Go / no-go gauges. A simply small L shaped piece of copper wire . IF I remember correctly I used standard 13 amp solid wire and also 40 amp which were thw correct gauges. Remember with the shims you have to do the entire rocker assembly not just one pedestal
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    You can always flatten a piece of copper wire with a vice or hammer and check the thickness with a micrometer. I always set mine closer to the 20 Thou as this will give less pump up potential at high revs.
    1. Rover V8 Challenge
      By jifop in forum History Archive
      Last Post: 21-04-2016, 18:02
    2. Rover alternator
      Last Post: 12-06-2009, 12:19
    3. rover 5sp manual box
      By hotrodguy in forum Stuff - FOR SALE
      Last Post: 15-05-2009, 19:30
    4. rover v8
      By pompeypaul in forum Tech Discussion
      Last Post: 04-05-2009, 17:37
    5. Rover V8 - Offers, Surrey
      By Smithy in forum Stuff - FOR SALE
      Last Post: 24-04-2009, 20:35
