rover v8 radiator question.
Results 1 to 7 of 7
    Official RnS Addict crumble's Avatar
    Jul 2009
    herts
    1,910
    crumble is offline
    What size inlet top hose and outlet bottom hose should be on a radiator to suit rover v8? I think I was told 35mm but not sure now. Could anyone confirm what size the should be.
    Gear head Lemon's Avatar
    Feb 2010
    Loughborough
    601
    31
    Lemon is offline
    Hey up John,
    If no one has answered by the time I finish work, Ill measure up and let you know!
    Cheers,
    Drew
    More than it shoud be, but not as much as it could be
    Official RnS Addict 1stpop's Avatar
    isle of sheppey kent
    2,484
    48
    1stpop is offline
    I'm pretty sure my 3.9 water pump pipe is 40mm John
    Dazza
    Jul 2009
    Yeovil, Somerset
    1,762
    822
    Stroprock is offline
    My water pipes are 40mm also.
    Feb 2010
    Loughborough
    601
    31
    Lemon is offline
    Just checked, mines a 3.5 litre and has 35mm top and bottom on the rover rad. 40mm water pump spout, 38mm outlet at the engine
    Jul 2009
    herts
    1,910
    crumble is offline
    Cheers lads. So 35mm inlet and outlet on the rad should be ok then.
    2,484
    48
    1stpop is offline
    You will need a stepped hose on the bottom to pump then 35-40 , so I would check your water pump 1st mine is 40mm so I had my rad made with a 40 mm bottom pipe so hose was easier
    1. radiator question
      By 100ev8 in forum Tech Discussion
      Last Post: 07-02-2010, 15:07
    2. Rover V8 dizzy question.
      By Tarmac Tanner in forum On Topic
      Last Post: 15-09-2009, 22:45
    3. Rover SD1 ign. question ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 05-09-2009, 15:25
    4. rover v8 distributor question
      By harris66 in forum Tech Discussion
      Last Post: 23-08-2009, 17:35
    5. Rover P6 Gearbox question
      By matt100e in forum Tech Discussion
      Last Post: 08-08-2009, 09:32
