rover v8 rough running and non start issue
Results 1 to 5 of 5
    I'm a newbie !
    Aug 2014
    banbury
    2
    alsmithy is offline
    Hi, im currently doing some work on my friends 100e with a sd1 rover v8, and I have a bit of a running issue, the car has been garaged for the last few years but has been stared regularly with no problems, I have been tasked with geting the pop back on road, which has all been straight forward until I started it last week.
    before I go into what the problem is I will tell you whats on the car, it has a early sd1 3.5 v8 with a 4160, 390cfm 4 barrel carb and a opus type dizzy with ballest resistor.
    My problem is this the first time I stared it I had a probably with the carb, which was the float operated fuel valves were not closing and flooding the carb I sorted that by striping them out and cleaning them out I thn reset the float levels as per the holley instructions, I put the rough running and not ideling down to this, so yesterday when I fired up the following happened the second I touched the key it instantly burst into life happy days I thought but it still ran rough but much beter than before then I attempted to let it idle and it stopped, not to restart again, so I checked for a spark and there was one present, and fuel pump was still running and the float bowels were full, I then give it spray of easy start and still nothing, so at this point I retired to a cold beer, then today I went back out to it today and exactly the same fired up straight away again still ran rough below 3500rpm but over that it ran loverly and I kept it running for a bit then attrmpted to let it idle again it stopped and would not restart, at this point I gave up again , and had a look online and found that the opus dizzys are very problematic, and cause very similar problems to what I have, does anybody have any other ideas of what may be causing this issue, as this is my first venture Into v8s.
    thanks
    Jun 2009
    1,829
    v8ian is online now
    Once Rovers wet their plugs, they will not clean up, no matter what you do, I used to have a drawer full of discarded Rover plugs I would suggest tomorrow, Mark the plug leads, looking from the front of the engine, No 1 is on your right, and all are odd Nos on that side, 1.3.5.7, even on the drivers side remove the plugs, no matter how new they may be, and fit new ones, before fitting, with the old plugs out, floor the throttle and spin the engine over for a few seconds to dry it out,
    I'm a newbie !
    Aug 2014
    banbury
    2
    alsmithy is offline
    I had the plugs out and they seemed ok, so regapped them and put them back in, but I wilk try a new set tommorow thanks
    Official RnS Addict rp460's Avatar
    May 2013
    Peterborough
    622
    40
    rp460 is offline
    Might be worth getting hold of an OE dizzy cap and rotor. The RV8 are well known for needing the original cap n rotor.many a problem with aftermarket items
    1932 Ford Model A Coupe
    1940 Ford Coupe
    Jun 2009
    1,829
    v8ian is online now
    Quote Originally Posted by rp460 View Post
    There are some discrepancies with RV8 rotor arms and caps, Some rotor arms sold to fit earlier dissy don't work, Early arms are lower than later ones, (Thats from Memory) resulting if you mix them on occasion you can either not have the rotor arm contacting the pegs in the cap, or, wiping the arm out and cap sometimes,
    1. Rover V8 Lucas distributor and MSD ignition
      By specialshoe in forum Tech Discussion
      Last Post: 11-04-2012, 14:58
    2. Rover 3 speed auto and torque converter
      By russ6120 in forum Stuff - FOR SALE
      Last Post: 24-01-2012, 16:38
    3. Advice re. non start FI engine
      By Roscobbc in forum Tech Discussion
      Last Post: 18-10-2011, 09:07
    4. Rover 3.9 pistons and rods
      By fozwanger in forum Stuff - WANTED
      Last Post: 15-07-2011, 04:44
    5. Rover sd1 v8 engine and auto 'box
      By simon p in forum Stuff - FOR SALE
      Last Post: 28-01-2010, 23:06
