Rover V8 SD1 oil sender advice please
Results 1 to 5 of 5
    Official RnS Addict Gotzy's Avatar
    850
    9
    Gotzy is offline
    Howdy All
    Just took a car in part exchange with Rover SD1 3.5l V8 and having oil pressure gauge problems. Car is running perfectly fine but the Smiths electric gauge isn't moving at all.
    From what I can see the green and yellow wire on the top sender is connected to the gauge. Haven't yet located the final destination red, green and white wire on the lower sender.
    From googling away I believe the following to be true
    1. The oil pressure sender / transmitter is a single pronged sender.
    2. The oil pressure safety switch is a 3 pronged switch.
    So, it would appear that my sender and switch are wired incorrectly, anyone got any thoughts on this?
    And can anyone confirm what should be installed where using the numbers below?
    Also, I assume these work on ohms, does anyone know what readings the senders should be putting out?
    Thanks
    Stephen
    Feb 2010
    Essex
    792
    dodgeman is offline
    Both of those senders are for lights, not for a guage. The one with 3 terminals is from an SD1 and does the oil warning light and cuts the feed to the electric petrol pump if the light comes on. The single terminal one is just a normal oil warning light sender.
    You need a proper guage sender unit.
    Sep 2011
    Kings Lynn
    3,199
    464
    brading is online now
    Hopfully these help
    kent
    2,971
    choppedblownpop is online now
    850
    9
    Gotzy is offline
    Cool, I was suspecting the wrong items so that sorts me out!
    Cheers
    Stephen
    1. advice please sd1 v8
      By kitcar paul in forum Tech Discussion
      Last Post: 03-01-2012, 19:54
    2. 3.9 v8 rover oil sender help!
      By mk1v8escort in forum Tech Discussion
      Last Post: 13-12-2011, 19:05
    3. Oil Cooler advice please.
      By Bumper in forum Tech Discussion
      Last Post: 10-10-2011, 19:50
    4. Rover SD1 oil
      By Classic in forum Tech Discussion
      Last Post: 22-02-2011, 19:24
    5. Rover man gearbox advice..please
      By insanityvans in forum Tech Discussion
      Last Post: 09-05-2010, 15:26
