rover v8 timing and firing order
Results 1 to 7 of 7
    Nov 2012
    KIRKBY WOODHOUSE, nottinghamshire
    1,947
    69
    cc41memorylane is offline
    Just managed to get my v8 fired up but after switching 1 and 8 around. All the ads 180. But no 1 cylinder was at TDC and the rotor arm to no 1 cylinder. Why the hell didn't it fire!!!!!!!!
    It would seem I was wrong and Kingy was right...
    Would anyone care to shed any light on the subject??
    Thanks in advance
    Trigger
    I'm not the best welder in the world.... but I'm in the top 5!
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    But was no1 at TDC on the firing stroke or the exhaust stroke?
    Nov 2012
    1,947
    69
    Firing. Both valves were shut. I've took the dizzy out and stuck the rotor a 180 and put the leads back to its original position. Ive never been wrong bit somethings stumped me.
    Rods 'n' Sods Junkie MGBV8's Avatar
    Jan 2010
    Buckingham
    336
    MGBV8 is offline
    I'm confused by this post ? You mention stuff about re setting the rotor position and putting the leads back to their original position. But I cant see any comments about this above? The firing order for your Rover should be 1-8-4-3-6-5-7-2.
    The common mistake is to fit the plug leads with 5 and 7 mixed up.
    If your number one cylinder was TDC on a compression stroke and you had all the plug leads fitted correctly it should have fired up assuming you had fuel and spark ?
    If you had to swap 1 and 8 leads to get it to start did you just have these two leads in the wrong holes in the dissy cap?
    On most RV8 engines with a dissy number one plug cap on the dissy faces almost to the front of the engine. Have you done a proper TDC check on number 1 cylinder with a TDC tool to mkae sure you know the true TDC of number 1 cylinder?
    MGB GT V8 with modified Rover 3.9
    9.62 seconds on the 1/4 mile
    Nov 2012
    1,947
    69
    Quote Originally Posted by MGBV8 View Post
    It would appear I had it on a exhaust stroke. My rushing the other night had caused me a slight cock up.
    As to the rotor arm. I pulled the dizzy out and spun it 180. No 1 lead is now point back toward the front of the motor.
    Just a few fuel leaks to sort and it should be ok
    https://youtu.be/omFNCMOZFnE
    May 2010
    luton bedfordshire
    1,660
    gazzmyster is offline
    video looks good hope that wasn't the fuel ****ing out underneath lol
    Nov 2012
    1,947
    69
    Quote Originally Posted by gazzmyster View Post
    No I haven't got hoses sorted yet but I stuffed he garden hose down the hole while it had a few fire ups. The headers need gaskets but all the time I spent a making them and I don't like the sound. What to do
    1. Rover V8 carb and manifold
      By john64 in forum Stuff - WANTED
      Last Post: 18-10-2010, 11:36
    2. Rover v8 block and crank
      By ThomasHarris in forum Stuff - FOR SALE
      Last Post: 04-08-2010, 14:09
    3. Rover V8 Dipstick and Tube
      By fingers in forum Stuff - WANTED
      Last Post: 03-08-2010, 12:50
    4. Rover V8 engine and box
      By zzpop in forum Stuff - WANTED
      Last Post: 22-03-2010, 12:18
    5. rover v8's and lots of parts
      By rangiemadbarney in forum Stuff - FOR SALE
      Last Post: 15-02-2010, 16:27
