rover v8 timing question
Results 1 to 3 of 3
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Willys V8 is offline
    Fitting a new cam on my rover v8 with new clyoes chain gears etc, got timing marks on gears spot on as I slide them on but when pushed fully home marks are slightly out, not by much 2-3mm , the engine was checked at tdc, but it might have moved slightly when I fitted new flywheel? So do I need to move crank slightly or cam slightly? Many thanks
    Banned
    Jun 2010
    wirral
    1,278
    386
    2
    Found out that's just the way cloyes make them!
    Herts
    4,600
    198
    WB54 is offline
    Assuming it he can wheel is adjustable, get a degree wheel and time the cam according to the specs based on true TDC. Once you're happy, check valve to piston clearance with plasticine.
    1. rover v8 timing
      By steve o in forum Tech Discussion
      Last Post: 30-10-2011, 20:07
    2. Rover V8 dizzy question.
      By Tarmac Tanner in forum On Topic
      Last Post: 15-09-2009, 23:45
    3. Rover SD1 ign. question ?
      By Tarmac Tanner in forum Tech Discussion
      Last Post: 05-09-2009, 16:25
    4. rover v8 distributor question
      By harris66 in forum Tech Discussion
      Last Post: 23-08-2009, 18:35
    5. Rover P6 Gearbox question
      By matt100e in forum Tech Discussion
      Last Post: 08-08-2009, 10:32
