rover v8 twin turbo loses power under load
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 30
    Mar 2012
    leed uk
    366
    28
    mcmental is offline
    hmmm more questions now folks, rover 3.5 v8 twin draw thru turbos running through twin SU carbs, car sits and ticks over lovely but as soon as i slip it into gear (auto 3 speed) the revs drop down and nearly stall, i can drive it but theres no power what so ever, if i blip the pedal it revs up and wants to set off but then it bogs down straight away, fuel regulator is set at 5psi at the minute.
    driving me potty is this as i need the car running for my wedding
    please help
    cheers
    chris
    Oct 2012
    surrey
    628
    2
    you do have oil in the dashpots.....just thought i'd ask!
    sounds very lean to be doing this
    neil
    Mar 2012
    leed uk
    366
    28
    mcmental is offline
    if its in D R 2 or 1 it loses power, neutral is fine though.
    kent
    2,900
    choppedblownpop is offline
    Vacuum hoses connected properly ?
    Does the auto have a vacuum supply ? (I don't know,I'm a manual)
    Mar 2012
    leed uk
    366
    28
    mcmental is offline
    im going to check the vacuum hoses now, theres also 1 going to the brake servo
    Mar 2012
    leed uk
    366
    28
    mcmental is offline
    do the vac hoses go to the inlet manifold?
    kent
    2,900
    Oct 2012
    surrey
    628
    2
    its not under load when in neutral though is it...?did you check the oils level with the top of the su piston tube
    have you had it running correctly at all,or a new build?
    ignition leads bad?/plugs slightly fouled
    neil
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    Now the engine has been turbo charged all the vacuum stuff that went on the inlet will have to be moved outboard to the stubs between the carbs and the turbo. As soon as you get on the gas the manifold gets pressurized and you will be left with no brake servo or crankcase vac.
    Bob
    Feb 2013
    uranus
    2,118
    ivanhoew is offline
    needle profiles need changing ,prob also need stronger springs .is it showing lean on stumble ?
    1. Mk2 Cortina Lutus twin turbo V8
      By alan in forum The Garage
      Last Post: 25-12-2015, 15:10
    2. Twin Turbo 4.0 Rover V8 :D
      By Monster_Moggy in forum Stuff - FOR SALE
      Last Post: 15-04-2012, 16:10
    3. Rover sd1 twin plenum injection complete set-up
      By Willys V8 in forum Stuff - FOR SALE
      Last Post: 28-02-2011, 19:36
    4. 1956 Chevrolet Bel Air – Twin Turbo Street Eater – 31
      By NoJive 55 in forum Tri Chevys, Spirit Of the Fifties and the Tuck Up Squad boys
      Last Post: 12-12-2010, 11:03
    5. BBF twin turbo set up
      By fozwanger in forum Stuff - FOR SALE
      Last Post: 03-07-2010, 22:35
