Rusty water
Results 1 to 10 of 12
Thread: Rusty water
    S.E London
    5,717
    513
    vince-305 is offline
    Rusty water
    Rust within the water jacket any sugestions on how to get the water running clear or just put up with it
    Bit'z 'N' Piece's
    south east kent
    889
    35
    THE VIKING is offline
    I would always run with coolant may help clean it up over a period of time ?
    23,734
    Always use antifreeze as it's also a corrosion inhibitor. Antifreeze also keeps any rust moving so it doesn't settle in the rad and block it. 50/50 mix will aid cooling as well.
    489
    langy is offline
    Give it a few good flushes with Rad flusher then do as Kev says.
    S.E London
    5,717
    513
    Thanks gents
    How about with the engine sitting on the stand with no heads on any good measures i should take to remove what rust is there ????
    Bit'z 'N' Piece's
    JC.
    V8 addict JC.'s Avatar
    Alfreton, Derbyshire
    1,102
    JC. is offline
    When I've had this in the past, I've connected the hose pipe up to the engine and forced water through in the opposite direction it would normally go.
    A lot of the crud will get dislodged. You should then use the appropriate type of coolant as mentioned above.
    -JC.
    Leyland
    872
    Shedster is offline
    Just for information, I think you'll find 'coolant' is a bit of a misnomer (I looked into all this a while back when I had a bike that was very marginal on cooling). The very best for heat dissipation is plain old pure water (with the possible exception of 'water wetter' to break the surface tension down, but a couple of drops of soap would do the same thing). Adding 'coolant' actually decreases the cooling effect (although only slightly), but does help with anti-corrosion (and could be said to help lube the pump as well). Coolant (ie anti-freeze), does give the necessary protection from icing, and also increases the boiling point (although if you've got boiling problems you really need to locate and fix the problem at source).
    23,734
    That's my background Odgie , 15 years in the car radiator trade ,and antifreeze definitely drops running temperature , even conducted tests with hand held laser thermometer to back up incar gauge.It makes at least 5C and up to 10c difference over plain water.
    Now whether that would be the case on an unpressurised system I don't know, never had the call to check it out
    Water wetter makes a 10-15C drop though never tried the 2 together. I try to make sure the rad is speced to cool well without aids.
    Boiling is a relative term ,I prefer' overheating' as different cars have different requirements and modern cars run at very high temps that we wouldn't be happy with in older motors.
    If you check back in tech section ( seach 'overheating' ) on the NSRA site you'll see a thread by Klunk where we worked together to impove the cooling on his Rover and he shows what difference each step made in his application.
    Hornchurch, Essex
    2,550
    9
    30psi is offline
    IIRC pure water is better than pure antifreeze, but mixed together 50/50 the heat capacity and cooling effect of mix is way better.
    South West Essex
    4,093
    14
    Roscobbc is offline
    Biggest mistake I ever made was to drain-off the water on a laid-up car through winter so it wouldn't feeze-up. The core plugs just rusted-out so the next time I used it thay just burst through. The amount of rust scale in the block created later issues
    1. rusty bonnet
      By roverman in forum Chat
      Last Post: 17-05-2010, 21:11
    2. A very rusty chassis with v5c
      By 5w31a in forum Stuff - FOR SALE
      Last Post: 12-05-2010, 22:35
    3. two very rusty chassis with v5c
      By 4potter in forum Stuff - FOR SALE
      Last Post: 28-01-2010, 12:44
    4. Old, rusty and rotten!
      By Ratrod 1 in forum On Topic
      Last Post: 19-01-2010, 12:25
