scimitar axle narrowing?
Results 1 to 10 of 12
    Official RnS Addict digger's Avatar
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    can a scimitar axle be narrowed easily?
    nowhere
    6,695
    2327
    nobody is offline
    yes
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    The Salisbury 4HA casing has straight parallel tubes, so isn't especially difficult to narrow the case. The splines on the halfshafts are pround of the halfshaft end, so it would be difficult to respline them. CPS drivelink (up Gateshead way) will cut and friction weld your shafts. This cost about £125 per shaft a couple of years ago
    Stuart.
    My Intro
    Jun 2009
    Rayleigh Essex
    3,118
    278
    trevd is offline
    if its an early axle the hubs are on a taper on the shaft so would be easier to re-machine the tapered end than cut splines.
    have a look here Graham Walker Ltd
    Sep 2011
    Kings Lynn
    2,980
    377
    brading is offline
    trevd looking at the Graham Walker diagram there is a shoulder just behind the taper which I take the bearing presses on to hold the shaft in. Though I suppose you could weld a new sleeve on in place of that on a shortened shaft to do the same job.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by trevd View Post
    Quote Originally Posted by brading View Post
    In the photo below there is a Scimitar 4HA shaft on the right. There is a collar to retain the taper roller wheel bearing. However, as the bearing surface is also the largest part of the shaft on the ones I've seen, turning a new taper, cutting a new keyway and screwcutting a new thread would still require a sleeve with a new bearing surface and collar to be shrunk onto the shaft. The "new" bearing surface would probably still require finish machining afterwards to get the bearing fit spot on.
    Have done quite a few new taper, keyway and screwcut thread jobs on early Austin halfshafts in the past. It takes the best part of a couple of hours per shaft on those, even doing them in small batches.
    Stuart.
    My Intro
    Jun 2009
    near ipswich
    3,404
    2784
    digger is offline
    cheers guys.....
    Jul 2009
    three holes, wisbech, cambs
    5,029
    939
    352 kum is offline
    i would look at mgb or i will pull a shaft and have a look
    Milton Keynes
    931
    14
    Magman is offline
    Quote Originally Posted by 352 kum View Post
    I would second using an MGB axle as, weirdly, with very little machining you can fit 9” Ford internals in one
    http://www.enigmaracing.co.uk
    A work in progress....
    Jul 2009
    5,029
    939
    352 kum is offline
    Quote Originally Posted by Magman View Post
    front loading early mgb or later rear loader?
    1. volvo axle narrowing
      By jifop in forum Tech Discussion
      Last Post: 31-07-2016, 21:08
    2. Scimitar axle measurement
      By Johnny in forum Tech Discussion
      Last Post: 16-10-2010, 17:04
    3. reliant scimitar axle,
      By harris66 in forum Stuff - WANTED
      Last Post: 01-06-2010, 09:30
