Seeking help :How to specify a transverse leaf spring
Results 1 to 7 of 7
    Nov 2009
    Hampshire
    61
    9
    doctor rod is offline
    I believe that the transverse leaf spring on my model T is both too weak and too short resulting in virtually no suspension travel. I would like to have a custom spring manufactured and would be grateful for advice on how to specify the spring. The car is running a Ford Beam axle (38.5 inches between perch centres and 48 inches between king ping centres, that seems to equate to a 37-41 Ford ?) The spring is mounted directly above the axle via perches and shackles, suicide style, with the spring mount protruding from the front of the chassis. The current spring is "reverse eye" to get the ride height low, however the spring is almost flat when under load. The axle is supported with split wishbones.
    I have had the quarters weights properly measures and I have weighed the front axle/hubs/wheels etc to estimate unsprung weight. What I am struggling with is how to specify the spring shape, size and spring rate. Or should I simply provide information to a spring manufacturer and let them work it out - although I am nervous about getting the ride height right.
    I have attached pictures showing the suspension loaded and unloaded
    Can anyone help please? Many thanks, Brian.
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Interesting problem. No doubt if you contacted a good spring manufacturer, with all the sizes, they could advise.
    Would it be possible to get the spring re-tempered, to give it less travel.
    I can recommend Jones Springs in Darlaston, who do an excellent job at sensible prices.
    23,660
    Rods 'n' Sods Junkie 100ev8's Avatar
    wolves
    437
    66
    100ev8 is offline
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    There doesn't look to be very many leaves in that front spring. Getting it rebuilt with a couple of extra leaves put in would increase the spring rate if it's too weak.
    I've used a company called Brost Forge in N. London to do my leaf springs. They've always done good work with a quick turnround.
    Stuart.
    My Intro
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    BTW,
    if you want to get an idea of how much difference changing the number of/thickness of/width of leaves in the spring will make, there is a handy Microsoft Excel spreadsheet macro that you can download from here that allows you to just enter the numbers: http://www.jalopyjournal.com/forum/s...d.php?t=202296
    HTH.
    Stuart.
    My Intro
    Nov 2009
    Hampshire
    61
    9
    Thanks for the advice. Can anyone suggest what sort of suspension travel I should be aiming for ?
    Thanks, Brian.
    1. Lowering a leaf spring
      Last Post: 20-05-2010, 19:47
    2. Replies: 6
      Last Post: 13-05-2010, 20:53
    3. Setting up a transverse rear spring??
      By crozch in forum On Topic
      Last Post: 09-05-2010, 21:16
    4. Lowering a car with transverse leaf springs
      By mgleadow in forum Tech Discussion
      Last Post: 07-03-2010, 15:44
    5. leaf spring 30s Ford
      By 32vertex in forum Stuff - FOR SALE
      Last Post: 13-02-2010, 15:49
