Servo problem
Likes Likes: †0
Results 1 to 9 of 9
Thread: Servo problem
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    Servo problem
    The servo on my truck seems to have packed in. Iíve checked the pipe and admittedly itís not servo pipe but hasnít collapsed....I can blow through it easily.
    Do these after market servos have a reputation of breaking down or am I being a nob and doing something wrong?
    If it is the servo at fault does anyone know who stocks a replacement?
    Russ
    Feb 2010
    Essex
    719
    dodgeman is offline
    I take it that as it's not servo hose you've checked that it's not collapsed when the engine is running.
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    I did think about that just after I finished posting. Can I replace the pipe with copper? I’ve got loads of that
    Russ
    nowhere
    6,496
    2234
    nobody is offline
    you could run it in copper. think you would need 10mm.just put a small vacuum hose joint at either end.
    ive had the aftermarket unbranded ones not work out the box.cheap chinese ****
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    Don’t get me started on cheap Chinese ****.......causes me more problems at work than the apprentice does.
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    I changed the pipe work to copper last night and it didn’t seem to make any difference. So if anyone knows where to buy a replacement servo that would be appreciated
    Russ
    Sep 2011
    Kings Lynn
    2,853
    326
    brading is offline
    If you have any idea what the original is off you can get one from Rockauto
    Jun 2016
    Roswell, New Mexico
    604
    NMNeil is offline
    Remove the check valve, that's the black plastic thing the hose connects to, and make sure you can only blow through it one way. If it's OK run the engine for a moment then turn it off. Pull the check valve out of the grommet on the booster and if you don't hear air going in to fill the vacuum the servo is leaking internally.
    Nov 2011
    suffolk
    5,974
    1410
    russ6120 is offline
    Thanks for that. I’ll give it a go tomorrow if I get time
    1. Servo or no servo?
      By chaley in forum Tech Discussion
      Last Post: 16-02-2015, 15:11
    2. Viva brake servo and master cylinder
      By ThomasHarris in forum Stuff - FOR SALE
      Last Post: 06-10-2009, 21:28
    3. servo
      By sd156 in forum Tech Discussion
      Last Post: 18-06-2009, 09:53
    4. Servo pipe twin screw in union V6 Essex
      By petespops in forum Stuff - WANTED
      Last Post: 02-06-2009, 21:19
    5. Mini heater. Brake servo.
      By Lee in forum Stuff - WANTED
      Last Post: 27-04-2009, 19:04
