Setting timing with no timing marks
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    6,170
    1023
    English Impala is offline
    I've set the timing on the Ranchero best I can (it runs & pulls well) and tried to set it with a strobe, but it seems like the timing marks on the balancer are in the wrong place, the strobe isn't picking them up (they're painted white).
    I have no idea why (yes, the strobe is connected to plug number one) so is there another way of setting the timing without using a strobe?
    May 2016
    S E London
    839
    22
    timbo56 is offline
    You need some sort of reference even if you a test bulb and not a strobe. Find true TDC and adjust the timing pointer to the timing mark and go from there.
    6,170
    1023
    When I set it up initially I used a whistle in No.1 plug hole to find TDC but was concerned that wasn't accurate enough to time it properly. It's all a bit odd as the balancer is perfect and it runs well....... I'll use the whistle again to find TDC tomorrow and go from there.
    Dec 2012
    winsford
    339
    221
    boblester40 is offline
    What ignition set up ? MSD box ? or plain HEI
    Official RnS Addict mattblack's Avatar
    Nov 2013
    A damp lock-up
    555
    70
    mattblack is offline
    Advance it till it pinks. Retard it till it doesn't...
    50 shades of grey primer....
    May 2016
    S E London
    839
    22
    timbo56 is offline
    Quote Originally Posted by English Impala View Post
    Every day is a school day, what do you mean "used a whistle"?
    Jun 2016
    Roswell, New Mexico
    600
    NMNeil is offline
    As already said you will need a static reference point.
    Take out #1 spark plug. Get a length of fairly rigid plastic or rubber hose that will fit into the spark plug hole. Make it about a foot long so there is no way in hell it will drop into the cylinder. Turn the engine over while holding the hose until you feel it being pushed upwards by the piston. When it stops moving upwards rock the engine back and forwards a few times until you get the exact point that the hose stops moving upwards. Make a mark on the crank pulley in line with your reference mark. Now continue turning the engine in the same direction until the hose starts to move downwards. Again rock the engine back and forth until you get the exact point the hose starts moving. Make another mark on the pulley. Using eyeball and guesswork make a mark between the two previous marks. This is your true TDC.
    6,170
    1023
    Quote Originally Posted by timbo56 View Post
    I used a rubber pipe that was a tight fit in the plug hole and pushed a whistle in the other end. When number one was on the compression stroke the air was pushed out of the plug hole & through the whistle, when it stopped whistling it was (near enough) at TDC.
    6,170
    1023
    Thanks
    up north
    1,989
    35kid is offline
    Quote Originally Posted by mattblack View Post
    agreed.
    1. Replies: 0
      Last Post: 18-07-2012, 17:29
    2. help with ignition timing?
      By scrapyarddoguk in forum Tech Discussion
      Last Post: 27-02-2012, 18:28
    3. Setting SBC Timing Video
      By Gotzy in forum Tech Features
      Last Post: 01-03-2011, 08:03
    4. 292 y block timing marks
      By barney 66 in forum Tech Discussion
      Last Post: 01-07-2010, 19:40
    5. help with timing a V8 60
      By keith ardley in forum Tech Discussion
      Last Post: 04-07-2009, 08:57
