single wire cooling fan switch
Results 1 to 10 of 15
    dek
    Rods 'n' Sods Junkie dek's Avatar
    fife scotland
    377
    5
    dek is offline
    how do you wire one of these up.
    i've only ever seen switches with 2 wires
    S.E London
    5,712
    513
    vince-305 is offline
    Well the only things ive ever known to only have a single wire (temp sender and oil pressure switch) both screw into the engine block thus working on the negative/earth side
    Where does your switch mount ?
    If its in the rad then is it metal or plastic ?
    Bit'z 'N' Piece's
    dek
    fife scotland
    377
    5
    dek is offline
    i have the temp sender for the gauge in the intake already.
    i was looking for a thermostatic switch to operate the fan but all i have found so far are single wire.
    it for a 302 3/8npt thread. will going in the stat housing
    dek
    fife scotland
    377
    5
    dek is offline
    http://www.speedwaymotors.com/Electr...nsor,2349.html
    like this.
    instructions are actually there as well.
    still dont understand how it works though
    Hornchurch, Essex
    2,515
    9
    30psi is online now
    It earths out the -ve wire coming off the fan, switching it on. Instead though set it up to earth out a relay and then wire the fan in to the relay. Simple really
    I use a Revotec adjustable controller than goes in line in the rad hose.
    Official RnS Addict UK RUSS 1960 OLDS's Avatar
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    UK RUSS 1960 OLDS is offline
    Quote Originally Posted by dek View Post
    Hi dek,
    Not being able to see the switch you are refering to, this is purely guess work.
    I am guessing the switch you are refering to, is dependant on a certain level of heat to switch it on to create a circuit and has a metal housing which would be the earth (effectively the second wire).
    If this is the case you would run a live feed straight to the fan (preferably via a fuse for safety and maybe also via a relay depending on the amount of current to be drawn) run the other wire that comes off of the fan to your thermostat switch. When the thermostat switch gets up to tempreature it will earth out to the engine block creating the circuit.
    Please also note the amount of current the switch can handle before wiring up as this may also dictate the need for a relay to be installed in the circuit.
    Where possible i always try to use relays as this reduces the load on older/existing wiring plus also puts less load on the switches/switching devices.
    It is much easier to get/find relays than it is to replace say the head light switch on your 1960 Olds for example.
    The only downside to this is you need a bit more wireing but it is better than having something fail or your car burn to the ground.
    If you need any help, you can always give me a bell.
    Cheers.
    Russ. 07762 - 747643. 10.00 - 22.00
    dek
    fife scotland
    377
    5
    dek is offline
    cheers guys.
    simple when explained
    Jul 2009
    HUNTINGDON UK
    11,239
    10317
    like this.
    Hi dek,
    Just seen this post, must have gone up while i was typing mine.
    That switch will earth out through its body, so effectively the metal body is the second wire.
    I would definately wire that via a relay to be on the safe side if you need any help let me know.
    Cheers.
    Russ.
    dek
    fife scotland
    377
    5
    dek is offline
    so i have a 30amp fused live to the relay .
    then the wire to the fan which will be live when the relay switches.
    earth from the fan.
    wire from thermostatic switch to relay.
    where does the other relay wire go .?
    Hornchurch, Essex
    2,515
    9
    30psi is online now
    The 30 amp live feed goes to both the +ve terminals on the relay (30 & 86)
    The 85 pin goes to the sensor. 87 then goes to the fan +ve terminal and then you earth out the fan -ve.
    Or you can do it so the relay is earthing out the fan by running the current though 30 and 87
    1. Cooling problems
      Last Post: 22-04-2010, 09:56
    2. Single wire alternator - recon'd
      By Flathead Meltdown in forum Stuff - FOR SALE
      Last Post: 17-01-2010, 18:59
    3. Cooling fan
      Last Post: 26-08-2009, 17:13
    4. one wire alternator , wire amps help
      By Steve 5-6-7 in forum Tech Discussion
      Last Post: 28-07-2009, 21:28
    5. 17" Cooling Fan
      Last Post: 22-07-2009, 20:06
