sbc cam replacement
Likes Likes:  2
Results 1 to 10 of 17
    nowhere
    6,829
    2363
    nobody is offline
    sbc cam replacement
    hello
    i have a truck in.it apparently had a new cam fitted elsewhere,and the truck has been fired up befor it came here.
    on removing the rocker covers,it seams all the rockers are loose.
    bit of googling suggests that the cam may of had the lobes wiped !!! does that sound about right.
    owners happy to have another cam fitted. is it as simple as sliding one out and putting the new one in. (i read up on setting the valves) engine as far as we know is a stock 350 chevy.is there such thing as a stock cam to put back in.
    at the moment the manifold is off and it has no dizzy in.
    is this a doable job for a simpleton.
    thanks
    nowhere
    6,829
    2363
    nobody is offline
    https://www.summitracing.com/int/par...make/chevrolet
    would something like that be suitable. seams to be lots of variations
    see most come with lifters.should i put new lifters in
    thanks
    wayne
    23,278
    You need to coat the lobes in assembly jizz of your choice and the oil needs to be no newer then SF spec as it lacks the amount of zddp lubricant necc for flat tappets. Also have to be started and immediately loaded and run in for about 20 minutes with no load or idling revving from 1200 to 2500 to vary static loading whilst cam beds in.
    Can a simpleton do it ? Installing cam is straightforward as is setting lash. Difficult part is getting distributor in on correct stroke and setting timing to fire straight away as you don't want it cranking over for ages to remove the lubricant jizz. Speak with Mark , he's done his so should be able to do that part for you.
    As for stock cam it's probably just as cheap to fit a light performance cam , don't forget it'll need new followers regardless of what the current ones look like.
    23,278
    thanks
    wayne
    YUp, 260 duration is a nice usable cam with a power increase without getting into additional machining.
    nowhere
    6,829
    2363
    nobody is offline
    thanks kev
    i understand about the break in bit on new cams. the first one we did the timing was out.those headers glowed very red,lol(my own car)
    actually break in a fair few new/rebuilt engines here on builds ,and am happy with setting initial timing.etc. just never really done anything thing insde an engine befor.
    im guessing id be better of getting the cam with the lifters as it all matchesthen.
    thanks
    for reply
    Herts
    4,601
    198
    WB54 is offline
    few things to check.
    1, Drop the oil, strain it, look for glitter or flakes in the oil. Check the cam surface for obvious damage, check the underside of the lifters.
    2, Pull the oil filter and look up into the block filter recess. Theres a hole in there where the filter bypass sits. If that's plugged with a threaded plug in there, then it s a fair assumption all oil has been filtered before going to the main bearing. Cut open the filter with chisel / snips, should see all the debris in there. Clean the pan, strainer, pick up, open / clean the oil pump, change the filter and take you chances on a new cam / lifters and some debris in the motor.
    3, If that bypass is unplugged and free to open, odds are the debris from the cam has gone through the bearings, in which case, it's a total strip / clean out / rebuild with new shells if needed..
  9. Likeskapri, magneto liked this post
  10. #7
    nowhere
    6,829
    2363
    nobody is offline
  11. #8
    23,278
    That looks like a headgasket as well then Needs full strip is nothing obvious when head removed as always possibility of cracked block.
  12. #9
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    I have this spare if interested. Brand new in box as I've changed plan and I'm going big block now. Also have some spare small block engines and big blocks too if you get stuck
    £250 posted on that cam kit
  13. #10
    8,879
    1759
    blackpopracing is offline
    That does not look too good.
    Real Steel probably just as cheap as Summit now with the poor £ if you were going to change cam.
    1. Replies: 3
      Last Post: 04-03-2011, 21:40
    2. consul classic leaf springs replacement?????
      By koolhandluke in forum Tech Discussion
      Last Post: 06-12-2009, 20:31
    3. Jag' hub felt bushing replacement?
      By staleg in forum Tech Discussion
      Last Post: 25-08-2009, 06:16
    4. B52 replacement?
      By 30psi in forum What, Where, When ?
      Last Post: 19-05-2009, 22:39
