SBC centre bolt heads
Results 1 to 10 of 10
    Dec 2010
    Near Canning Town, London
    1,783
    1857
    Taxirod is online now
    I'm replacing one SBC with another.
    The last one had normal heads, replacement engine has centre bolt heads.
    Question is, will my same inlet manifold fit?
    I notice that the new heads have the bolts in the middle at an angle, with the others about 90 degrees to the surface. Previous heads had all inlet manifold bolts at 90 degrees.
    May 2015
    Somewhere West of London
    134
    2
    Test or Kill is offline
    Sounds like Vortec heads, some people use non Vortec intakes by grollying out the holes. You should really buy a Vortec-compatible manifold but we're all cheapskates at heart so what have you got to lose by playing with stuff? HTH
    Cheers, Martin
    Maybe I'm just sick in the head.
    Oct 2012
    South London/NI
    2,158
    721
    Stude Star is offline
    As above but they you can get centre bolt heads that us e a normal intake. L98/113 heads use a normal intake but are centre bolt. Vortec heads use Vortec intake unless you drill the holes as Test or Kill says.
    Post the head number.
    12,931
    i've fitted an early (up to '86) inlet on a later ('87 on centre bolt valve covers) engine mate. as martin says above i just elongated the holes as the bolts are at a different angle. it all worked fine with no leaks so i'd do it again if it's what i had.
    Dec 2010
    1,783
    1857
    Thanks y'all for the info.
    Head numbers are:
    14102183 (or maybe 93)
    Also one head has "GM24" and the other has "GM21".
    If they are Vortec heads, does that raise the comp ratio on a 305?
    South Norway
    207
    staleg is offline
    These are not Vortec heads.
    Vortec head numbers ends with 062 or 906
    Are you sure it's not 14102188?
    1988-93 - 14102188 - 350 - 1.94 - 1.5001 - 76CC - EFI, swirl port
    Sorry to say, but swirls port heads are not a very good starting point for a performance build.
    They are very restrictive to give a high speed on the air/fuel mix on low rpm's, but because of the restrictive channels, run out of air around 4000 rpm's.
    Good judgement comes from experience, and a lot of that comes from bad judgement.
    12,931
    Quote Originally Posted by staleg View Post
    he's got the 6:71 to help with airflow
    Feb 2013
    uranus
    2,164
    ivanhoew is offline
    Dec 2010
    1,783
    1857
    I was told that they are big valve heads, I think with all the various issues I will probably just put it all together and see how it goes.
    As Neil says, the blower will help push more mixture through whatever.
    South Norway
    207
    staleg is offline
    1.94/1.5 valves
    14102193 Details - Casting Numbers .info: engine blocks, heads, and more
    Also be aware that restrictive intake channels makes the blower work harder wich would heat up the air temperature.
    And hot intake air could lead to detonation.
    1. SBC TPi Plenum STAINLESS Bolt Kit = ROGUE BOLT
      By Dr.Feelgood in forum Stuff - FOR SALE
      Last Post: 24-03-2017, 20:57
    2. turn key sbc 350 centre bolt **price drop**
      By 24v in forum Stuff - FOR SALE
      Last Post: 23-01-2015, 17:33
    3. Replies: 0
      Last Post: 30-11-2012, 13:47
    4. Replies: 4
      Last Post: 15-11-2011, 20:27
    5. Replies: 11
      Last Post: 30-04-2011, 20:44
