SBC inlet manifold
Results 1 to 9 of 9
    Rods 'n' Sods Junkie Matiz's Avatar
    Jan 2014
    Gloucester
    233
    16
    Matiz is offline
    SBC inlet manifold
    New to this Chevy engine
    On underside of inlet manifold is a shaped metal plate held in by four pins. What is it for ?
    I have removed it and it is absolutely full of oily hard bits of carbon ? ?
    Oil contamination may be where i have been cleaning outside of manifold prior to removing plate
    cheers
    "call 0-800 Apocalypse" satan's Avatar
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    its the splash shield to keep oil off of the exhaust crossover. make sure you get the 4 pins secure when replacing it as you dont want them rattling around the motor.
    And I heard a voice in the midst of the four beasts, And I looked and behold: a pale horse. And his name, that sat on him, was Death. And Hell followed with him.
    Jan 2014
    Gloucester
    233
    16
    Matiz is offline
    ok thats great
    so maybe a bit of thread lock in order then.
    Mine splash guard is full of hard carbon i assume its exhaust build up so presumably my manifold gaskets have been leaking !
    12,881
    no its oil fumes built up and baked hard
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    You could leave it off and block the crossover passages in the heads. a good few aftermarket manifolds dont have them. the blanks are usually included in the gasket set. If you choose to refit it I recommend using new pins.
    Jan 2014
    Gloucester
    233
    16
    Matiz is offline
    Some good advice thanks.
    So whats the exhaust crossover for ?
    Is it like the link pipe between the two exhausts I used to have on my old TR7 V8 ( rover ) to help scavinge the cylinders ?
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Quote Originally Posted by Matiz View Post
    Not really, the pipe you refer too is a balance pipe. the one in the inlet manifold is and aid to cold weather driveability. most of the performance orientated inlet manifolds dont have them as the cooler charge aids fuel density. hence the benefits of intercoolers. there is much info on this on the internet and opinions do vary, have a bit of a search round and read up before you decide.
    Jan 2014
    Gloucester
    233
    16
    Matiz is offline
    Ok thats great info.
    Also on the manifold is a small bore steel tube that has a loop that goes inside this crossover pipe .
    On the outside of manifold it is connected by rubber tubing to back of rochester quadrajet at the top and then to what is left of what i think was the auto choke on the right hand ( as viewed from driver position ) of the carb. The chokes on carb have been " wired " open.
    So presumably this was also some sort of heating device and that i can bypass this loop if I blank off the crossover pipe, which is what i am tending towards doing.
    I wont be using this as a daily driver, more for a bit of weekend fun, if I can get engine swap registered at DVLA.
    I'm a grown up member now ! nitrousnutter's Avatar
    Oct 2011
    margate
    76
    nitrousnutter is offline
    I'm just building a sbc with a quadrajet as well, just had a quad built in America for mine, the man that did it told me to tap the two holes that go down from the carb crossover with 3/8 (10mm) and plug them, as it was used to stop carb icing but it didn't really work and ends up heating carb too much, there was a factory recall in he late sixties as a few cars caught fire. I guess your intake has an oil filler tube, so it's from 1967-1969, they are a nice period looking intake tho, just block the two holes and it will be fine, you do need the crossover to be open tho from head to head as is works the thermostatic choke spring, again you can wire the flap under that plate so it doesn't close and cause problems with choke operation. Have a read on google that's where I learnt about it there's a lot of late 60's camaros still using them...
    1. sbc inlet manifold gasket
      By dez58pop in forum Stuff - WANTED
      Last Post: 18-08-2013, 21:57
    2. SBC Inlet Manifold
      By rusty old tin in forum Stuff - WANTED
      Last Post: 29-05-2011, 17:00
    3. sbc inlet manifold & bits
      By 58 delray in forum Stuff - FOR SALE
      Last Post: 16-09-2009, 00:16
