SBC Power Steering Pump Bracket
Results 1 to 3 of 3
    Slowly but surely Barneys66's Avatar
    Jan 2010
    Bury St Edmunds
    923
    143
    Barneys66 is offline
    Can you help ?
    My truck's got the running gear from a '77, plus an older Goodwrench motor. It came to me with old ramhorn manifolds (which have now been replaced by headers) and the p/s/pump was mounted on bodged bracketry.
    I've seen aftermarket brackets to use with headers, but anyone know if there's an original set-up from another Chevy that'll work...?
    I'm a grown up member now ! Crank 2's Avatar
    Mar 2010
    South East
    46
    Crank 2 is offline
    Re: SBC Power Steering Pump Bracket
    Barney, there are quite a few. Check out the photo's on http://www.alangrovecomponents.com/, http://www.billetspecialties.com/subcategory.asp?cid=25 and http://www.marchperf.com/csb_brackets.html. You will then have an idea of which pump you have and where it's positioned on your block. Normally the frame rails and type of pump dictate the mounting. Hope this helps.....
    Jan 2010
    Bury St Edmunds
    923
    143
    Quote Originally Posted by Crank 2 View Post
    Many thanks
    1. 1962 Lincoln power steering pump, 430ci
      By Clean Kev in forum Stuff - WANTED
      Last Post: 12-04-2010, 13:04
    2. WANTED: Steering column to dash bracket 55 Chevy truck
      By Motorama in forum Stuff - WANTED
      Last Post: 27-02-2010, 19:25
    3. ford sierra power rack and pump/pipe's
      By 1968unclefester in forum Stuff - WANTED
      Last Post: 11-02-2010, 22:47
    4. Power Steering
      By gramps in forum On Topic
      Last Post: 30-01-2010, 18:41
    5. Power steering??
      By cabby in forum On Topic
      Last Post: 22-06-2009, 23:02
