SBC Sender question
Results 1 to 4 of 4
    Chuckinmuck since 1966
    Oct 2010
    Essex
    1,125
    104
    Chevy Chaser is offline
    SBC Sender question
    Hi Guys - doing some re wiring on Chevy.
    I have Oil & water temp guage and they have capillary fittings so they are all good.
    My engine has another electrical sender located under left hand exhaust manifold - Would that be a water sender as it is in the head ?
    Also Just behind the oil filter again on left hand side is a small hole that has a square headed blanking cap screwed in - I am presuming this would be a good place for a oil sender ??
    What I am trying to do is fit an oil sender pressure switch to wire into my fuel pump so if engine stops then pump will also, also this can feed the dash light to show low pressure.
    anyone please ?
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    On an SBC (assume that's what you have?) the heads aren't handed, so there are two potential water sender points on the motor -one on each head. Usual place for the oil pressure sender is the 1/8 NPT tapping in the centre of the V behind the manifold, this tapping goes into an oil gallery so it sees what the bearings see, a tapping near the oil filter will see the pressure the oil filter sees which would probably be a bit higher as there's a surprising amount of hydraulic drag in the oilways.
    I put a tee piece in the guage oil pressure line to run a warning light on my truck.
    Stuart.
    My Intro
    Oct 2010
    Essex
    1,125
    104
    Cheers Stupot
    up north
    1,987
    35kid is offline
    the port in the head is usually used for a temp sender for an electric fan
    1. SBC cam question.
      By Mark Bull in forum Tech Discussion
      Last Post: 20-04-2013, 21:07
    2. SBC oil filler tube and gm tank sender/ pickup
      By chris57post in forum Stuff - WANTED
      Last Post: 07-03-2011, 16:09
    3. Fuel gauge/sender question
      Last Post: 24-03-2010, 15:00
    4. SW speedo sender question
      By rodbuilder in forum Tech Discussion
      Last Post: 12-03-2010, 17:45
    5. SBC dizzy question
      By zephyr in forum Tech Discussion
      Last Post: 30-09-2009, 11:36
