sbc water-crank pulley clearance? am i missing something?
Results 1 to 10 of 11
    Rods 'n' Sods Junkie Pittaway's Avatar
    Mar 2013
    Solihull
    471
    2
    Pittaway is offline
    hi all,
    come to fit up the pulleys on my sbc, and the pulleys are touching. only slightly but still binding. i know they are only aftermarket chrome items, is it just bad tolerances on the manufacturing?
    bit confused here.
    any help be greatly appreciated
    thanks
    May 2016
    S E London
    850
    22
    timbo56 is offline
    I've got similar pulleys that aren't plated and can just about slide a thin bit of card between the two although my top pulley does just about touch the heater pipe inlet on the pump
    Herts
    4,568
    197
    WB54 is offline
    maybe a mismatched pair but mine are certainly close on the inner groove
    Official RnS Addict heavychevy's Avatar
    Jun 2009
    Sweet Home Northampton
    1,206
    47
    heavychevy is offline
    You could try remounting the pump but hold it as high as you can when tightening the bolts. The holes are a bit bigger than the bolts.
    12,563
    mygasser is online now
    Quote Originally Posted by heavychevy View Post
    that'll fix it, almost certainly the weight of the pump slid it down as low as it would go on the bolts while being fitted
    Mar 2013
    Solihull
    471
    2
    Pittaway is offline
    i tried moving the water pump but to no avail, i think i have mis- matched pulleys. the water pump pulley is 7.1" but they do 6.8" that should sort the problem
    Herts
    4,568
    197
    WB54 is offline
    Quote Originally Posted by Pittaway View Post
    or the other solution is to put a washer under each main bearing cap to space the crank from the water pump...
    12,563
    or elongate the the bolt holes in the pump a knats (that's a technical term) to give clearance.
    be aware also the smaller pulley will spin the pump faster.
    Neil.
    May 2016
    S E London
    850
    22
    timbo56 is offline
    Careful what you say, there are people stupid enough to do that, it's on the internet so it must be right
    Mar 2013
    Solihull
    471
    2
    Pittaway is offline
    turns out ive got a mis- matched set! been so long building this car i cannot remember where they came from, thanks for all the help though!
  1. Replies: 0
    Last Post: 29-12-2015, 08:12
  2. SBC short water pump crank pulley
    By Scottie999 in forum Stuff - WANTED
    Last Post: 06-02-2015, 19:34
  3. SBC crank pulley - to suit long water pump
    By dsapsfo1 in forum Stuff - WANTED
    Last Post: 02-03-2012, 14:17
  4. Am I missing something?
    By streetfighter in forum Chat
    Last Post: 04-05-2011, 21:51
  5. Luxury Loo Handle - Am I Missing Something Here!
    By xxxxxxxxxHotrod Girl in forum Chat
    Last Post: 30-01-2011, 20:32
