SBC water creeping up head studs
Likes Likes:  3
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Dec 2010
    Near Canning Town, London
    1,648
    1747
    Taxirod is offline
    Fired up new engine 1st time today, noticed water coming from some of the head studs.
    They were fitted by someone else, maybe they didn't use thread lock/sealer.
    I'm hoping to be able to remove one stud at a time and put back with sealer, after draining water down of course.
    What do you reckon?
    May 2016
    S E London
    870
    22
    timbo56 is offline
    I've never rebuilt a SBC but on my Jaguar engines with open nuts that leaked (they usually have domed nuts) I put a good RTV sealant around the studs under the washers, it always did the trick.
    Jul 2009
    three holes, wisbech, cambs
    4,975
    930
    352 kum is offline
    Quote Originally Posted by Taxirod View Post
    What do you reckon?
    typical vauxhall!!!!!!!
    Stroker Kustom Jim's Avatar
    Bath
    4,817
    2625
    Kustom Jim is offline
    I was gonna use studs on my SBC but ain't got the room to pull heads off when in car due to bulkhead overhang.
    But I do remember my research and apparently it's imperative to put loads of sealant goop on, some studs worse than others - it's a coarse thread in cast iron so even with pukka ARP studs ya up against it.
    I'd guess that as long as it ain't a high comp race engine then you could swap em out one at a time ( maybe slacken em off somewhat once all done and retorque together - I like the idea of studs as the threads being retightened are not in the old iron block but ARP bits on top of head ) but how ya gonna unwind it? May as well as pull em and be done with it then you could put on quality reusable head gaskets!?
    12,693
    sounds like a plan ian, one at a time only though.
    Dec 2010
    1,648
    1747
    Taxirod is offline
    Thanks all for your helpful comments.
    Ive got some Permanex sealant which Ive used on the inlet manifold gasket, that should do the trick?
    Herts. and ahead of Larry :)
    2,602
    34
    chevy2 is offline
    Yes Ian, some of the head bolts go into the water jackets on sbc's,
    You're supposed to run sealants on the threads,
    I reckon its worth a go, pull the studs one at a time and blow the remianing water out thiroughly with a air blow gun and then refit/torque them back one at a time with sealer on the threads.
    Jun 2016
    Roswell, New Mexico
    631
    NMNeil is offline
    I always coat the threads with this stuff, it's meant for the job.
    https://www.permatex.com/products/ga...-no-2-sealant/
    Oct 2012
    South London/NI
    2,156
    721
    Stude Star is offline
    Drain the coolant before you do it as the you’ll be screwing the bolts into coolant. In fact coolant will probably come out of the bolt holes if not drained.
    Obviously you can’t clean the threads in the block so just do the best you can. Really clean the studs and put liberal amounts of sealant on. Good luck.
    Sep 2011
    Kings Lynn
    2,907
    349
    brading is offline
    You should be able clean the thread a bit in the block if you get an old stud or a bit of threaded rod and with a cutting disc cut 3 or 4 slot length ways in it a bit like a tap. Then when screw it in hopefully some of the muck will end up in the slots and stay there when you screw it out.
    1. Long head bolts or studs for sbc
      By TheWebDesignCompany in forum Stuff - WANTED
      Last Post: 26-09-2017, 22:16
    2. Creeping
      By MannyT in forum The Showroom
      Last Post: 26-04-2016, 18:54
    3. Replies: 0
      Last Post: 03-05-2012, 04:59
    4. Replies: 4
      Last Post: 20-06-2011, 19:30
    5. snapped studs in a head.
      By marg in forum Tech Discussion
      Last Post: 16-01-2010, 18:32
