Smoking Rover V8?
Results 1 to 5 of 5
    Rod'a'holic rodbuilder's Avatar
    Glastonbury
    1,019
    721
    rodbuilder is offline
    Smoking Rover V8?
    I have a Rover 3.5 which has had new bearings and rings, it runs really well std spec with a modified manifold to take a Dgas 38 webber.
    On cold start it is fine no visible smoke, when at temp according to a mate following it shows a small amount of oil smoke at gear change.
    But when hot starting it throws out a large cloud also when pulling away there is some. it is using about 1/5L for 300 miles. Left side is the worst.
    Compression is just over 10 bar on all cylinders and the plugs are clear. The crank case breathing is just to the air filter.
    My thinking is valve stem seals ( which have been replaced) or guides. Could adding pcv valve to the system help?
    Any thoughts or suggestions before I take the head off.
    Cheers
    Rich
    Nov 2011
    ChristchurcH
    919
    Stinkeys is offline
    Well after spending many hours and lots of money on rover v8s in the past ( they sound good and fairly light in weight ) I'd say fit a small block instead? But I'm sure like most your on a budget ? And my meanderings don't help..
    Just a back yard hotrodder,learnt by mistake,still learning ?
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    You are on the money with the PCV. The rover lump is designed to run negative pressure in the cranckcase so I would get the pcv reconnected and see how it goes.
    Bob
    Rods 'n' Sods Junkie DEVONMAN's Avatar
    Oct 2010
    Croydon
    378
    7
    DEVONMAN is offline
    Rovers will smoke if you put too much oil in. Just 1/2 a litre over the mark can do it.
    Check that the dip stick outer tube is fully home.
    Official RnS Addict cptpugwash's Avatar
    Jun 2012
    shed
    1,870
    115
    cptpugwash is offline
    No expert but have an idea if the stem seals have gone brittle the engine will smoke when started from cold
    1. Rover V8 Challenge
      By jifop in forum History Archive
      Last Post: 21-04-2016, 18:02
    2. Rover alternator
      Last Post: 12-06-2009, 12:19
    3. rover 5sp manual box
      By hotrodguy in forum Stuff - FOR SALE
      Last Post: 15-05-2009, 19:30
    4. rover v8
      By pompeypaul in forum Tech Discussion
      Last Post: 04-05-2009, 17:37
    5. Rover V8 - Offers, Surrey
      By Smithy in forum Stuff - FOR SALE
      Last Post: 24-04-2009, 20:35
