someone help this young girl fix her car
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Rods 'n' Sods Junkie andy's Avatar
    edinburgh scotland
    410
    74
    andy is offline
    Had the camaro (86 5.o v out a few weeks ago for a bit rip,which it hadn't had for literally a year or so!! all was fine till heading home and the srvice eng light flickered, as it did the engine seemed 2 choke/lose power and it felt like it wanted 2 die, this was at about 10mph, then it cut out, started up 1st time and got me home which was less than a mile away thankfully, kind of kangarood all way home with light flashing intermittantly.
    did a error code check following night after leaving it to sit and showed up no codes and ran fine the other 2 times i had it out, however i took it out yesterday and gave it one boot on the way home an it started it's crap again, i pulled over an turned it off for a few mins but was still same all way home, then when got in would'nt hold a rev, was a bit spluttery, would say a misfire but is kinda hard to tell? too me anyway, cuts out if not on the gas and its sad there since how often do u reckon plugs and oil need changes it sometimes doesnt move for 4-5 ays at a time, could this be part of the prob? the fuel filter was so corroded 2mnths back the garage 'bypassed' it? as thts where the leak was but it runs fine untill caned? any suggestions wud be appreciated, thanx x
    Official RnS Addict vin likes diesel's Avatar
    London
    2,801
    1527
    vin likes diesel is offline
    No fuelfilter could cause no end of problems
    Pro Street Escort... MOT ready.
    Hug Street Morris Oxford mo.... unfinished, on its tenth set of wheels
    Custom truck ..MOT ready
    Dinner ....finished
    Official RnS Addict mikeyboy's Avatar
    San Diego.Calif USA
    2,422
    209
    mikeyboy is offline
    shoulda put a new fuel filter on it.
    There's no replacement for displacement.
    matt black is for chalk lil miss petrolhead's Avatar
    north lincs
    640
    228
    lil miss petrolhead is offline
    if the fuel filter was so badly corroded, theres every chance that theres crap in the rest of the fuel system,i would suggest a stripdown ,thorough clean, check the tank for scale/crud,check any steel fuel lines for corrosion,check any rubber fuel lines aswell as they can deteriate and you wind up with small specs of rubber blockin jets/injectors. then put a new fuel filter on,probably get a different garage to do the work, as the numpty that bybassed the filter is clearly a bodge artist.
    I'm a newbie !
    Dec 2011
    scotland
    19
    amyiroc is offline
    hey guys finally got registerd, thanx 4 replys, i gave the garage a new filter to fit an 'apparently' was to corroded to get on, it had new fuel lines last year, how wud i go about giving it a fuel clear out without to much stripping? pretty crap for garages that specialise in real cars around here ;(
    Official RnS Addict Slamera63's Avatar
    Feb 2010
    Hull, Yorkshire
    1,985
    Slamera63 is offline
    Was the new fuel lines put on by the same garage?, as already stated find a different garage cos this thicko could have caused you more serious trouble, if crap has got through to the injectors you've got a bigger problem as the injectors need to be cleaned, a bill that in my opinion should be paid for by the cowboys who by-passed your fuel filter. You dont need a "speacialist" garage to do a job like changing a fuel filter, this is just basic stuff.
    north lincs
    640
    228
    23,579
    New fuel filter back inline , then put some injection cleaner , available from Halford ( if you must! ), into your tank and run. This will help clean any light sediment from the injector tips. Problem may still be there in which case it'll need injectors removing and ulrasonically cleaning. Don't refit them until you are SURE the rest of the system is clean or it will be a total waste of time and money.
    Official RnS Addict lambretta_ash's Avatar
    Aug 2011
    birmingham, quinton/oldbury
    1,196
    287
    lambretta_ash is offline
    Quote Originally Posted by amyiroc View Post
    get some spanners and start playing girl
    well u can unscrew your fuel sender and look thru there for the tank part
    by what do i know i drive a 4inline a series engine none of these sexy v8 v mmmmmmmmmmm sorry gotta clean lmao
    Dec 2010
    Tokyo japan
    175
    32
    steven is offline
    I had the same problem afew months back it turned out to be water in the system.
    Ran fine and then cut out, once the fuel settled out it ran fine until it mixed again.
    All this was on an old v8 rover
    1. Replies: 2
      Last Post: 11-11-2010, 21:29
    2. Replies: 6
      Last Post: 08-08-2010, 18:31
    3. help..i need to get my car on a car ramp
      By jimo62 in forum Tech Discussion
      Last Post: 15-06-2010, 14:21
    4. Help - two vehicles to fix!
      By zephyr in forum Tech Discussion
      Last Post: 15-04-2010, 16:00
    5. Can someone help me...???
      By bigyellataxi in forum Chat
      Last Post: 23-04-2009, 17:31
