Spark problems 79 Dodge
Results 1 to 4 of 4
    Official RnS Addict chucks41's Avatar
    Jul 2010
    Thornaby
    1,277
    907
    chucks41 is offline
    My son's luck continues with his 360, 79 Dodge Lil Express truck.
    Breakdowns since begining August.
    1. Water pump failure
    2. Distributor cap & rotor replaced (last week)
    3. TQ Carb flooding replaced with Holley (yesterday)
    Tonight phoned up truck won't start.
    When checked no spark at plugs.
    Checked volts at +ve on coil, only shows 6volts, remove +ve wire from coil check across earth to battery, supply goes to 12v.
    Cleaned earth to block, changed battery for a fully charged one plus jump leads from mine, no difference, checked and cleaned all connectors (coil, terminal block on wing etc). Swapped coil to check volts still show 6volts
    Distributor is magnetic contactless system with two wires (Yellow/black & black) disappear into loom.
    Don't have workshop manual so can't follow wires.
    There are two modules on the bulk head. Passenger side, a silver one. Drivers side (left hand drive) a blue one I would guess this is the ignition amplifier module.
    Does anyone know if there are any checks I can do that I might of missed or how do I check the modules.
    The wiring is a real chop job with parts of the original loom taped up and replaced with god knows what.
    Truck had run fine this morning until parked up.
    Cheers
    Ian
    Too much time on my hands. Too little money in my pocket
    Official RnS Addict Zody's Avatar
    Sussex
    1,772
    Zody is offline
    Hi Ian
    There should be a second terminal on the starter marked R for resister, try
    running a new wire from there to the coil, that will give you 12v when cranking
    the engine to start up, also the module is the same they used on a XJ6, I fitted
    one to Jenson years back, worked a treat
    Good luck
    The car is open, the keys are under the dog !
    Jul 2010
    Thornaby
    1,277
    907
    chucks41 is offline
    Thanks Zody I'll give it a go in the morning, your mind goes to mush after a while
    Ian
    Jul 2010
    Thornaby
    1,277
    907
    chucks41 is offline
    Thanks Zody.
    Tried what you said but could not remove terminal nut on starter for small lead (danger of shearing it). Ran a lead straight from battery to coil when cranking.
    When we tried again with full battery, optima battery on jump leads and jump leads on battery from my Galaxy (3 batteries in all) the starter was turning slower than required to give the engine a good spin and still no spark.
    My guess is now starter is shagged and dragging voltage down too far to power coil. We have removed starter and ignition relay and taken them to our local auto electrics but it'll be Monday or Tues before we get em back. So we'll have to be patient
    Cheers
    Ian
    1. 350 Chevy TBI problems
      By Paul G in forum Tech Discussion
      Last Post: 28-05-2009, 12:27
    2. Dodge Ram SLT Limited edition
      By Zody in forum Vehicles - FOR SALE
      Last Post: 11-05-2009, 12:52
    3. 1998 Dodge Dakota doors & tailgate
      By THE VIKING in forum Stuff - FOR SALE
      Last Post: 04-05-2009, 21:24
    4. small block ford idle problems
      By JonF in forum Tech Discussion
      Last Post: 27-04-2009, 16:14
    5. Problems with Neon Light
      By 53catalina in forum Chat
      Last Post: 24-04-2009, 22:36
