Speedo - Gearbox problem, any help on this please.
Results 1 to 8 of 8
    Grumlins forTea! Russ D's Avatar
    Mar 2010
    Somewhere Between 1971 & 1989 - but mainly Wakefield in 2013!
    5,382
    72
    Russ D is offline
    Mate of mine has a Cobre with a 2litre fitted and a Type 9 Ford 5 speed box.
    Since we re-ritted the engine and new box the outlelt for the cable drive is in a different position to the previous box. Its now close to the chassis rail meaning that the cable wont go directly in, So cash in hand we got a 90 degree adaptor, but this was also too long to fit the space we have between the chassis and the box.
    So we thought Electronic, the question now is if he buys an electronic set up the pulse generator that needs to fit in the box - or does it? if it does has anyone any experience of this as to how long they are, or is there an alternative that can be driven just off the prop shaft needing nothing to be fitted into the cable hole in the box which canthen just be blanked off.
    Any advice would be welcom, weve scratched heads so much over this weve got bleeding heads!!!
    Thanks Russ D.
    http://www.nhrc.freeforums.net/ Light me an axle i'll be back for breakfast, (just nipping back to the 70's)
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    You should be able to find someting wich can use an external pickup. A mate of mine has a Westfield kit car, the speedo pickup is a bunch of magnets fixed around the propshaft flange. Think the instruments he used are VDO. CAI (who own the Smiths brand) do an electronic speedo which can use an external pickup too. Telemetrix
    Stuart.
    My Intro
    Mar 2010
    5,382
    72
    Russ D is offline
    anyone aware of how we cab ger the noemal cable drifen one working again?
    13,270
    alter the chassis to clear the 90 degree adapter you have.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by Russ D View Post
    Requires a bit of engineering, but what about taking a small belt drive from the propshaft slip joint to drive the cable via a pulley and spindle; this was the solution I was going to use with a Jag Getrag box which only has an electronic output.
    The propshaft slip joint would act as one pulley, The driven pulley would run on a shaft with the speedo cable connected to the end of it.
    You'd need the driven pulley to be about 4 times the diameter of the slip joint (check what your old box speedo drive ratio was to get it exact) for the drive ratio.
    A round section belt like those used on sewing machines would be all you'd need as hardly any power is being transmitted.
    Stuart.
    My Intro
    I'm a grown up member now ! macharper's Avatar
    Jul 2010
    falkirk, scotland
    39
    macharper is offline
    in this months copy of PPC mag (practical performance car mag)
    they have an electronic speedo for £100
    not sure if that saves you chopping and labouring away
    cheers
    macharper
    Mar 2010
    5,382
    72
    Russ D is offline
    Thanks for the advice boys, I think weve cracked it.
    Cheers Russ.
    Love this Forum for this kinda stuff especially.
    Mar 2010
    5,382
    72
    Russ D is offline
    May go for chassis option I think. Thanks all.
    1. Pontiac 455 Help on this 1 Please.
      By Robbi in forum Tech Discussion
      Last Post: 26-03-2011, 00:03
    2. Any Info or Help on this Please??
      By Pike in forum On Topic
      Last Post: 05-02-2011, 00:00
    3. I am looking for a 5 speed rover SDi gearbox if any one can help
      By gasser consul shane in forum Stuff - WANTED
      Last Post: 21-04-2010, 10:24
    4. does any one remember this pop?
      By sparky in forum Chat
      Last Post: 12-09-2009, 14:38
    5. help on this colour plz
      By neil harris in forum Chat
      Last Post: 14-05-2009, 07:58
