Squeaky springs...help!
Results 1 to 4 of 4
    Official RnS Addict Moparhemi345's Avatar
    Jun 2011
    boppin' around N. Kent
    2,792
    226
    Moparhemi345 is offline
    The rear springs on my truck have started squeaking.
    I've tried WD40, works for a day or so.
    Is there a dedicated product for this problem?
    I've had a good look under there and there isn't any rust as such, just the usual road grime. I gave both sides a good brush out as far between the leaves as I could get.
    Don't really want to dismantle anything if I can help it.
    Anybody had this problem and cured it?
    'Badges? We don't need no stinkin' badges!'
    Rods 'n' Sods Junkie fluff's Avatar
    Sep 2009
    south cerney glos
    274
    23
    fluff is offline
    squeeky
    i had that problem on my truck and what i did was loosen the u bolts jack up the truck by the chassis so all tension was off the springs and then sprayed the lot with motorcycle chain lube left it for 20 mins wiped all excess off then tightened all back up no more squeeks rich
    chevy man chevyv8t's Avatar
    wisbech
    88
    102
    chevyv8t is offline
    mix up some graphite powder with meths and spray between leafs the meths will evaperate and leave the graphite and then it should be ok
    Jun 2011
    2,792
    226
    Thanks fellas, I'm gonna give the chain lube a go first, I think Bel Ray do a fairly dry one, see how we go. If no joy will try the graphite. I've found a graphite spray lube on the web. Should work ok?
    1. Driving to Sofia, Bulgaria - HELP SOUGHT:
      By Battersea Boys in forum Chat
      Last Post: 07-01-2013, 20:38
    2. lube help needed
      By sqweaka in forum Chat
      Last Post: 06-05-2009, 15:54
    3. Du Pont solvent based paint - help
      Last Post: 06-05-2009, 08:00
    4. Help finding shocks
      By roofer in forum On Topic
      Last Post: 05-05-2009, 11:22
    5. Can someone help me...???
      By bigyellataxi in forum Chat
      Last Post: 23-04-2009, 17:31
