Starter motor
Results 1 to 4 of 4
Thread: Starter motor
    Rods 'n' Sods Junkie steveslittlelucy's Avatar
    Dec 2015
    Rudgwick
    102
    8
    steveslittlelucy is online now
    Starter motor
    Afternoon, I wonder if anyone can help,my sbc has always seemed slow turning over since I’ve had it and i wondered if the live wire was at fault ( the battery is in the boot) so this afternoon I replaced it but it’s no better, when I put a volt meter on the battery feed on the solenoid it was 12.4v but when I got the Mrs to crank it it only read 4.5v, does this mean I need to get the starter rebuilt or is it a power problem- I’ve tried 2 batteries that go up into the green on a drop tester and stay there and I’ve got 2 earths on the car and one of them comes off a starter motor bolt, any advice would be appreciated
    Steve
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    How big is the cable from the battery -you really need something bigger than the usual 12v size of 16 sq mm for a long run. Something like this should work OK. I would be inclined to run an earth cable in the same size direct to the starter too.
    https://www.ebay.co.uk/itm/Copper-We...qAM1f2xFKWHN2A
    25 sq mm cable is actually about 10mm diameter.
    Stuart.
    Hidden Content
    Dec 2015
    Rudgwick
    102
    8
    Quote Originally Posted by stueeee View Post
    Thanks for the reply, I bought some 21 mm 170amp wire off of eBay but I must admit It’s funny stuff , it doesn’t take solder that well, my father in law has some old arc welding wires that are quite long , I think I’ll do both like you suggested .
    Steve
    May 2016
    S E London
    1,001
    22
    timbo56 is online now
    It could be the solenoid is worn or not connecting properly or you have old cable and dirty connections. Mine was slow or wouldn't start when hot. I used 70mm 485 amp cable on my SBC plus I fitted a second solenoid with the switch wire jumped straight from the large starter cable connector.
    70mm2 485 A Amps Flexible PVC Battery Welding Cable Black Red 1 - 100M M Lengths | eBay
    As an after thought, is your switch wire wired correctly I.E. not running from a ballast resistor?
    Dec 2015
    Rudgwick
    102
    8
    Quote Originally Posted by timbo56 View Post
    I think tomorrow I’m going to get it up on the lift and put 2 very short leads to the starter to see if it’ makes a difference before I go any further and if that works I’ll use some welding leads, the wire to the solenoid comes straight from the ignition , thanks for the advice
    Steve
    May 2016
    S E London
    1,001
    22
    Quote Originally Posted by steveslittlelucy View Post
    Steve
    While you're doing that you could try putting a direct feed from the battery to the switch terminal on the solenoid (so you're bypassing the ignition switch) with some new wire to see if that makes any difference.
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Mine was always slow, but slowly speeded up........ In the end I replaced the starter with a hi-torque unit that was £100 from Russ Pepper. perfect after that! ...and as a bonus I was able to turn the solenoid down away from the exhaust to stop the ole SBC heat soak problem I had had for ages!
    Dec 2015
    Rudgwick
    102
    8
    This afternoon I put 2 short leads straight to the starter with a remote starter button and it turned over a lot faster so I’ve made a new battery holder and put it back in the engine bay so hopefully it’s sorted now, thanks for everyone’s help.
    Steve
  1. shimming a SBC starter motor
    By Motorama in forum Tech Discussion
    Last Post: 27-07-2010, 16:16
  2. BBC Hi Torque MiNi Starter motor
    By vince-305 in forum Stuff - WANTED
    Last Post: 07-05-2010, 21:49
  3. Staggered pattern Chevy starter motor for GMC Vandura
    By fall-apart-dave in forum Stuff - WANTED
    Last Post: 05-03-2010, 10:43
  4. 103e starter motor
    By tappets in forum Stuff - WANTED
    Last Post: 05-11-2009, 20:57
  5. Rover v8 starter motor...
    By ThomasHarris in forum Stuff - WANTED
    Last Post: 23-07-2009, 20:26
