Starting problems
Results 1 to 4 of 4
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Starting problems
    Time to appeal to others of a similar nature again, my problem is starting to annoy me, and defy logic.
    I have a truck, with a super powerful 1703 straight 4, and low compression head, about 7:1.
    During summer months, it starts on the button, and runs no problem at all. Just recently, it will not go without a jump. Off a booster, it goes straight away, and I tried it once with just a ten second charge, and away it went.
    Yesterday, went for a spin, had to boost it, and drove to a mates, about 3 miles away. So it was nicely warmed up, I turned it off, wouldn't start. Jump started it, and away.
    We got to where we were going, about 30 minutes away, and I left it running. Turned off. Waited a minute, and not enough oomph in battery. 5 minutes later, and she fired up, on first click.
    Now I am starting to get annoyed with it, I can usually suss electrickery, but this has me scratching my head. Battery is new (ish) off a Transit, so 590 CCA. If it willl turn a 2.5 HC diesel, it should do an old fourpot. I have earths from battery to chassis, chassis to block, battery to block. All with good connections, and star washers under bolts to bite into connections.
    New starter motor fitted Saturday.
    The only thing I have not checked is a remote solenoid, the original was a push button starter which I did away with. Has anybody ever have one of those go high resistance, cutting volts to starter motor?
    It all points to a knackered battery, but why should it not start, then start 5 minutes later?
    Suggestions please.
    Andy
    Official RnS Addict StueyT's Avatar
    Peterborough, Cambridgeshire
    2,341
    317
    StueyT is offline
    Hi Andy,
    It sounds like a dead cell in the battery to me, if you can get it charged and take it to a battery centre they can usually test them and tell what is wrong, it was a free check last time I did it have you tried another battery that is known to be good?
    Cheers,
    Stu.
    Nov 2009
    stourport
    5,531
    7
    beach57 is offline
    Some thing is getting hot ,then when leaving it cools down.
    Rods 'n' Sods Junkie doorslammerpop's Avatar
    Nov 2010
    sent to coventry
    142
    15
    doorslammerpop is offline
    sid you need to put the other half of the engine in
    on a more serious note, sounds like the battery is up the swanny, you might be getting the voltage but not the amps .
    1. Todays conundrum - Starting problems !
      By unityjon in forum Tech Discussion
      Last Post: 16-09-2010, 10:56
    2. fuel sender/slow starting
      Last Post: 09-06-2009, 18:16
    3. 350 Chevy TBI problems
      By Paul G in forum Tech Discussion
      Last Post: 28-05-2009, 12:27
    4. small block ford idle problems
      By JonF in forum Tech Discussion
      Last Post: 27-04-2009, 16:14
    5. Problems with Neon Light
      By 53catalina in forum Chat
      Last Post: 24-04-2009, 22:36
