Stat o seal washers on banjo fitting in brake system?
Likes Likes:  1
Results 1 to 10 of 13
    South Norway
    207
    staleg is offline
    I have read several positive reviews on different web pages (Summit, Jeg's, Amazon etc) from customers that have good experience with rubber bonded "stat o seal" aluminum washers on brake calipers.
    But I know for positive that at least some of the brands are not compatible with brake fluid. (Earls's, among others)
    Funny thing is that when i ask other brands ( Goodridge, Drag Specialities etc) the refuse to answer. "Unfortunately we are unable to comment on this application." "we are unable to comment on brake fluid compatibility" etc etc.
    If the rubber used on the washer is not compatible with brake fluid, why don't they just say so?
    Is it like "We want to sell them, but don't want to know what they are used on".
    Good judgement comes from experience, and a lot of that comes from bad judgement.
    Jun 2009
    Rayleigh Essex
    3,139
    280
    trevd is offline
    loom up a company called hydrahose Hydrahose service Ltd | UK’s Leading Suppliers of Hydraulic Equipment & Fittings. , they deal in everything hydraulic and run a dragster so know a bit about car related seals. they are on facebook and ebay. ytel them I sent you and they will sort out exactly what you need, top quality and probably cheaper than inferior stuff from America.
    nowhere
    6,831
    2363
    nobody is offline
    What's wrong with using copper washers.
    You can get an expanded type copper washer from think automotive.never had issues with them
  5. Likesmygasser liked this post
  6. Remove Advertisements
  7. #4
    Jun 2016
    Roswell, New Mexico
    760
    NMNeil is offline
    Quote Originally Posted by staleg View Post
    Because if they say it's fine for your braking system and it fails causing a crash, they get sued.
  8. #5
    May 2010
    west yorks
    2,166
    68roadrunner is offline
    Those are sump plug washers, why the fk anyone would use something that has a means of "transport" for the fluid (rubber bit) is beyond me.
  9. #6
    Jun 2016
    Roswell, New Mexico
    760
    NMNeil is offline
    Quote Originally Posted by 68roadrunner View Post
    They are also used to seal A/C pipework.
  10. #7
    South Norway
    207
    staleg is offline
    I found it.
    These are compatible with brake fluid.
    https://www.ebay.com/itm/HARDDRIVE-3...53.m2749.l2649
  11. #8
    Sep 2011
    Kings Lynn
    3,077
    430
    brading is online now
    I do not see where it says they are compatible with brake fluid. For safety if you do decide to buy some put one in a tub of brake fluid for a while to see if it affects the seal or not before you fit them.
  12. #9
    South Norway
    207
    staleg is offline
    I asked the store where they are sold.
    Classic Cycle parts. Existed since 2001. 337534 items sold, 99,6% feedback rating.
    Here are another similar version:
    https://www.ebay.com/itm/Brake-Fitti...53.m2749.l2649
  13. #10
    South Norway
    207
    staleg is offline
    All this fuss about the banjo washers are because I have bought a set of Wilwood "GM direct replacement" calipers, that typically wasn't quite as much direct replacement as promised.
    And because stupid me painted them before I saw the problem, they are not returnable.
    The trouble is the fitting. They are equipped with 1/8" npt fittings (most Wilwood calipers are) and to make a long story short, the adapter fitting that I need to fasten the brake hose, either interfere with the lower sliding bolt, or, if I use a hose with 90 degree bend that goes down below and around the sliding bolt to clear it, it interfere with the lower A arm on my IFS suspension at full turn.
    The Wilwodd-recommended way to do it, is the alternative that interfer with my lower suspension A arm.
    Because these calipers (according to Wilwood) are mostly used on racing classes where GM caliers are mandatory, they haven't had this issue earlier. I bought them directly from Speedway Motors in the US.
    So now I'm trying a couple of different alternatives, without compromise on security. Photos show a 3/8-24 banjo bolt into 3/8-24 IFF fitting.
    threads are correct and the surface around the hole is large enough for the washers. Thread engagement is a bit less than desired, that's my only concern. By using washers with o-ring on the inside, my thought was to make it seal properly with less torque. I sent same photos to Wilwood and they didn't see anything wrong in plumbing it this way.
    Haven't quite decided yet. Maybe I just give up the caliper change project and use the heavy iron GM calipers that I have. Lots of money out of the window, tow. Or maybe i worry too much. Not sure....
