Steering.
Results 1 to 10 of 14
Thread: Steering.
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Steering.
    I understand the pitman arm and drag link should work in tandem. Now, I can't see the pitman arm properly, but can see the drag link. With the wheels pointing straight, it points front to back in a straight line. I'm guessing this is right.
    Is it?
    13,456
    mygasser is online now
    what car's this on mark?
    3,426
    185
    Mad Mark is offline
    A big red and white one Neil.
    My '55.
    The reason I'm asking is I'm checking all the set up on the front suspension and this is checking the middle set of the steering.
    The lower A-arm seems to have been damaged and I can see a gap between the front face of the A-arm and the back of the bush.
    I can't apportion blame, but it wasn't me. It's been hit on the front edge bending the lip down and pushing the front bushing mount rearwards.
    I've checked the caster (1deg pos) and camber (1/2deg neg) and the car is still wandering a little, enough for me to lose total confidence, whereas before I could chuck it around.
    nowhere
    7,114
    2413
    nobody is offline
    Can you not get a portapack in and bend it all forward again.if you can up the caster angle you will find it shouldnt wander,but thats prob depends on the state of the rest of the components
    23,666
    All systems may vary in details so really it needs a specialist in Tri chevies to answer that . The standard steering box set up would me a steering box with pitman arm and an idler arm bolted to the opposing chassis leg . These two turn at the same speed/ ratio to one another to move track rod tie rods at the same time. This is done via a drag link that connects pitman arm to drag link.
    The first thing to do would be a 4 wheel laser alignment , available at most top end tyre suppliers to see current camber caster ,kpi etc setting along with alignment of front to rear axles. Cost around £30 round here . Before spending out you need to ensure no play at all in steering components including those that may have been replaced BEFORE the accident .
    13,456
    as wayne says add a bit more castor and it'll feel more stable. from memory its shims on the upper wishbone. remove from the rear and/or add to the front to get more castor, then have it rechecked. the a arm damage sounds like speed bump type impact, had similar myself before and had to straighten the arms.
    Official RnS Addict Steve 5-6-7's Avatar
    Stuck in the 70's
    3,386
    527
    Steve 5-6-7 is offline
    Mark before you go any further you must remember Rule One of steering geometry.
    If any single part is worn, bent, loose or damaged the geo will be useless
    That even includes the wheels you must ensure everything is sound before you start.
    When was the last time you rebuilt the front end ?
    They were shimmed from new .
    Steve Hale had his geo set up last year by a hot rod shop, it might be worth getting them to sort it out once you have you have replaced anything that is ****ed
    Sorry if I repeated anything mentioned above
    Nostalgia.......it's the future
    Stuck in the 70's
    3,386
    527
    Ecklers sell shafts with 2° positive camber.
    3,426
    185
    Mad Mark is offline
    I understand all that guys.................. NOW!!! I have changed the caster from 1deg neg to 1 deg pos already but need more shims to get any further.
    No, it's not a speed bump one Neil. It's hit something solid and unmoving...... like a raised drain cover. I'll have to take the arm off to get to checked and a guy named Simon from the Trifive facebook page has a spare pair of A-arms and he'll keep them for me for when I get down to pick them up.
    Still need a definite answer on the bent arms effect on the way she drives???
    Stuck in the 70's
    3,386
    527
    Quote Originally Posted by Mad Mark View Post
    Bent = wrong = drives ****. That's as definite as I can put it.
